Just letting you all know I have my Digitrax installed and rolling. As of now all I have are DC locos but they run better on DCC than on DC. I cannot tell a lot of difference right now except the throttle is a WHOLE LOT MORE precise than with the DC. I have a couple of DCC locos on order, and would like to know about installing decoders, what is involved? I am running N scale and have never even seen a decoder. Is there certain things that I should be aware of? Thanks. Mike
First off, you are entering the world of DCC and so we are speaking the same language, I will make a few adjustments to your terminology.
You have DCC READY locos on order. A DCC loco already has a decoder installed. Good to know when you are ordering your units.
Your title is a bit misleading and confusing. You have a new Digitrax? Would that be a new item from Digitrax, or a yet to be released system? From your post I have to assume that you have purchased a new Digitrax system. Could you please tell us which one?
In terms of installing decoders into DCC READY locomotives, it is a matter of removing the shell, removing the old light board, insulating where nessesary on the frame, installing the decoder in the same position and orientation as the origional light board, and reinstalling the shell. After the install I highly recommend that you check the decoder installation on the PROGRAMMING track. Resist the temptation of putting it on the layout and dialing it up. If you did anything wrong, you will fry your decoder.
David B
Hi, Mike
I like Digitrax also. Your Loco’s on order, are they DCC ready?
If yes then the loco will come with an dummy plug installed where a decoder would connect.
All you have to do is remove the dummy plug.
Connect the decoder or it’s plug to the plug in the loco.or Tender.
Call up engine #3 and set the Loco’s address for dcc control.
You must beaware of the engine load stall amp draw. The amp rating of any decoder used most be over the engine stall speed amp draw.
You’ll find most one amp N scale decoders are OK for N scale use.
Remeber Decoders are also rated by the amount of circurts they control.
Enjoy your Trains.
N scale…N scale…no dummy plug. Replacement boards…
David B
