My New Lay Out Pictures 10-3-06
I thought I would up date you guys on my first layout with detail. So let me know what you guys think about it!
Engines
http://www.photolocker.net/images/BakersLayout/img1318.jpg
http://www.photolocker.net/images/BakersLayout/img1319.jpg
http://www.photolocker.net/images/BakersLayout/img1320.jpg
http://www.photolocker.net/images/BakersLayout/img1321.jpg
Track Work
http://www.photolocker.net/images/BakersLayout/img0417.jpg
http://www.photolocker.net/images/BakersLayout/img1338.jpg (this will be a river some time in the future but not that shap.)
http://www.photolocker.net/images/BakersLayout/img1336.jpg
http://www.photolocker.net/images/BakersLayout/img1333.jpg
http://www.photolocker.net/images/BakersLayout/img1332.jpg
http://www.photolocker.net/images/BakersLayout/img1331.jpg
http://www.photolocker.net/images/BakersLayout/img1326.jpg
Just a Couple of my Rolling Stock, trust me I have more.
http://www.photolocker.net/images/BakersLayout/img0428.jpg
http://www.photolocker.net/images/BakersLayout/img0429.jpg<
Progress is sweet. When will you have a circle done top run a train? Looks good. Thanks for the update.
Well for me to be able to run a train here is what I have to do I think. If I leave any thing out please let me know.
  1. Finish Laying Homasote, Cork, Track.
  2. Build 2 double track wooden tresles or 4 single track tresles.
  3. Run all the wiring.
  4. Fix it with wire plugs because it is made up of (12) 2’x4’ tables for moving made some what easier.
  5. Buy and wire up all of my switch machines (well wire them up enough to where I don’t have to pull up all of my switches later, leaving the power wires hanging under the table for now.)
  6. Install my MRC Prodigy Advanced DCC System.
  7. Install at least 1 of 4 Engine decoders.
  8. Program the decoder’s
    9.Brake in my engine
  9. Put an Engine and some frieght on the track.
  10. Turn it on
  11. tell it to go.
Did I miss any thing?
Baker
take pictures along the way :slight_smile:
I am good with the picture part. I just got a new Canon power shot A540 a couple months ago. I love it, there will be plunt of pictures along the way.
Baker
You’ve got a real good start there, James. You layout looks like mine did a couple of months ago, track and wires laying all over. You’ll get it sorted.
James,
Looking good. Keep the pictures coming, we really enjoy watching the progress.
Larry
You guys will never guess what I seen to day. I just about had to change my Pants!!
I took these pictures about 2 weeks or so ago.
http://www.photolocker.net/images/BakersLayout/5.jpg
http://www.photolocker.net/images/BakersLayout/4.jpg
Well I seen the same 2 engines in the same order today at work! Althought they where Hundreds of miles apart and on a completely different tracks. Although this time these 2 were pulling a pretty short load of box cars, tankers, 2 flats, 2 empty car hallers, grain cars insted of many rail cars full of rails!
Is there some where I can look up the track lay out for around my place?
Thanks
Baker
I’m sure glad you don’t like John Deere. :))
Looks good. Makes me want to finish mine!
Thanks,
Mike/Nightshade
jamesbaker:
Good work. Looks like excellent workmanship.
How wide is your layout? How do you access the center area for trackwork, scenery, etc.?
I have a 6’ wide table-top and can reach the center but wouldn’t go wider without some type of removeable panel.
My layout is made up of (12) 2’x4’ tabls screwed together. So when it gets down to that time I will be removing tables for final finishing. Although I plain do work pretty slow from here on out.
Once I get my trains running, I will need to get all the kinks out of the track. Then when that is done I will start on the buildings, then landscap. Once all the foam is fix the way I like it I will just run my trains for a month or so and make sure I don’t want to change any thing
Oh and I am just going to use homasote to cross my river for now. So I can run my trains while I build my tresles!
Thanks for the complaments on my work. I am trying my hardest to do thinks right! Well at lest what I think is right.
Once I get my wirring supplies this weekend I can start wiring things up.
Thanks Again
Baker
Great pictures. I’m actually doing something similar in that I’m starting my layout. I have all of my pictures posted here…http://traintrackblog.blogspot.com/
I look forward to more of your updates.
Great start, James - - looks like my Toledo Eastern Corridor switching layout looks right now - - wires and track laying all over the place. Right now, I only get to work on it on weekends. It’ll be interesting to see pictures of the progress.
I will be making a trip to one of my LHS tomorrow for supplies and lowes for some supplies!
Well I say LHS they are 45 minutes away and 1.45 hours away. So they are not so local really but they are the my LHS.
I need to pickup some cork, flex track, isalation rail joiners (for reverse loop), rolls of wire, plugs, and so on. So I should have a pretty hefty bill tomorrow. I will be sure to post pictures tomorrow of what all I get done. I should have all most all day to work on my layout, although I have to carve a pumpkin with my newfew tomorrow also.
Baker
I did not get as much done as I hoped. I just have my bus wires ran and I am now ready to hook my track feeders to my bus wires (i will have this done tonight), build a spot for my power source to sit, I need to buy some decoders.
In the mean time, my engines and rolling stock did not mined posing for some photos. Just for you folks!
http://www.photolocker.net/images/BakersLayout/img1391.jpg
http://www.photolocker.net/images/BakersLayout/img1390.jpg
http://www.photolocker.net/images/BakersLayout/img1386.jpg
http://www.photolocker.net/images/BakersLayout/img1388.jpg
http://www.photolocker.net/images/BakersLayout/img1384.jpg
http://www.photolocker.net/images/BakersLayout/img1378.jpg
http://www.photolocker.net/images/BakersLayout/img1379.jpg
http://www.photolocker.net/images/BakersLayout/img1377.jpg
Enjoy
Baker
Here is the update on my layout.
Baker
Looking good man!
Keep at it!
nice job on the lay out
I have one question. What is your cork road bed lying on top of?
Derrick
The stuff under my cork is 3/8" homosote. It is used as a sub roadbed and is used for sound deadening. Others including my self line subwoofer boxes with it. It helps with the sound qaulity. It is hard to come by in 3/8" thick, although you can find it in more places in 1/2" but you want the 3/8" stuff. It is made of some sort of paper. If you need more info you can do a search for it here and you can find many post about it. Oh and I think it is about $20.oo persheet (4’x8’x3/8")
Hope this Helps
Baker
GReat work, you like your John Deere And thoose Coal hoppers are pretty kool :slight_smile:
