My new layout on my new website
I’ve started building my layout and have made a new website to show my progression. Please check it out and of course upbuilding comments are more then welcome.
Janboulis Hobby Site
I would like it a lot better if I could see something other than the section list. I click on say bench work, but no pictures?
I like the backdrop, the blended sky colors look very good. Be sure to post updates as you post them! Jamie
I get a 404 not found error
Looks like a good start. Great benchwork and backdrop construction. It seemed like the sections (buttons) of your web site took longer to load than I would have expected, even without any pictures.
Mike
I turned off my firewall and did get to see the back drop and the bench, that was it. Is there more?
Cuda Ken
I agree, and I have a VERY fast connection, so I looked at the source.
Here’s a tip: There’s no need for frames and javascript on the pages you’ve created. They are very simple and would probably load a lot faster if you just used everyday HTML to build the pages.
I only saw a little bit of your work janbouli, due to glacial load times, but it looks nice. I’m jealous.
I will look in again sometime, hope you can fix the site so that it is a bit faster.
I could only get the backdrop and benchwork to load, and not sure if they fully loaded. I have broadband, by the way.
Myself, also, could only get the benchwork and backdrop images to load–and I’ve got very fast Broadband. However, your construction looks admirable, and I certainly like what you’ve done with your backdrop.
Is it possible to get a more thorough connection to your website? It looks as if you’re doing some fine work, there.
Tom [:)]
My fault, I should have made clear that other then the benchwork and backdrop page there is nothing so far , for the simple fact that my layout isn’t further then that. As for the speed of the website I just put this together real quick ( took me less then 2 hours ) and when I have time I’ll rebuild it in a simpler way. There is no java or flash in it that I know of, but I made it with a webdesign program so I’m not sure. When I rebuild it it will be made in Dreamweaver without any horns and bells. I was also pointed out that the resolution I chose 1280X1024 might be a bit large for most visitors, so I will also adress that point, my only excuse is that I built the site on a 1980x1200 full HD 24 inch screen and it looked very good.
Your entire site code for a page consists of about ten lines of javascript followed by framesets.
Whatever program you used is terrible!
