Mythbusters MRR Style - Feeder Wire Overkill?
Let me begin by saying that I mean neither to step on any toes nor offend any forum contributors’ sensibilities, but I’m often amused at the amount of construction overkill some have said is necessary in order to ensure a well-running layout. Take, for instance, the bomb shelter-like benchwork (3/4" birch plywood on L-girders spaced at 12", etc) that’s been described that just makes my jaw drop. But I digress…
There have been forum members saying it’s important to install feeder lines on every section of track (which gives about a 3 foot interval between feeders), lest we run the risk of poor running. I have begun laying track on my new layout - I presently have a touch over 20 feet of the mainline laid. The track joints are soldered on curves but otherwise simply butted with rail joiners along straight or gently curving areas. Last night I rigged up my old MRC Throttlepack (the one with the gold casing, that I’ve owned for about 30 years) with a couple of wires at one far end of the track and test ran some engines. My Protos ran the full length of the completed line flawlessly. Ditto my Genesis 2-8-2.
So, as an experiment, I got out Old Grandaddy - a 30-year-old Athearn SD9 that’s been sitting in a box for the last four years and hasn’t received a lick of maintenance of any sort in probably 10 years. I set it on the line and cracked open the throttle. It ran at a virtual crawl the full length of the line multiple times without stalling even once.
So to summarize, I ran an old beater of a locomotive at low speed off of an ancient power pack jerry-rigged to the rails and there was no perceptible loss of performance in the engine when it was 20 feet away from the feeders. And to boot, I’m certainly no expert at tracklaying. So what’s the necessity of powering the rails every few feet?
And I don’t want to be obtuse either, but why don’t you put that straight stretch of track in a box for ten years. After corrosion and wood movement from humidity have done their thing, come back and tell us how everything is running.
Good luck to you.
Lynda
Now to really test your theory.
Paint the rails and weather the track.
Inatall ballast and glue per normal procedures.
Clean track per normal procedures.
Run trains for 5 years.
Then see if your butt joints and rail joiners still provide the same level of conductivity as trackage that only relies on soldered feeder connections.
The point of the feeders is to provide long term reliability on the layout.
Lynda, that adds another degree of difficuly to the dive. The track I was using was salvaged from my old layout. It’s easily 10 years old and is anything but clean. So we have all of these factors saying this shouldn’t be performing well, yet it’s working. I’m just trying to start a dialogue here.
There’s nothing wrong with dialogue; I’m a writer, I love dialogue!
The thread below adds excellent issues to the mix; per ballasting, weathering, etc. I don’t think the question is whether your “unleadered” track sections work today, but if they’ll continue functioning efficiently in five or ten years. That you’ve used old track is probably a moot issue. When you rejoined the sections, or even jostled them, you created enough friction to refresh the contact areas between rail and joiner. The fact is, you may have good contact for some time, but through corrosion, sans well-soldered contacts of some nature, resistance will build. It’ll happen slowly, and you may not even notice it until electrical current is sufficiently interrupted. Think of the line of current flowing from powerpack to locomotive as a continuous link. All along the circuit, you’ve got many opportunities for electrical inefficiency. Doesn’t it seem prudent to minimize all potential failures under your control? Now, if you enjoy digging out ballast, adding leader wires later, and reballasting, that’s okay too. [;)]
Lynda
You’re absolutely right: it’s not technically necessary. My first layout, an old Triang-Hornby set, had a clip that connected the power pack to the track. It fed a big figure-eight layout with a few sidings and the locomotives only needed the occasional push. As a kid, I didn’t care.
Fast-forward a few decades, and now I’m feeding a larger, more complex layout not just track power but operating instructions as well. And for some unknown but clearly age-related reason, having to push a stalled locomotive now irritates me. Yes, it’s more trouble adding feeders to every section, but it pays dividends in trouble-free operation. Do you want your trouble now or later?
Mononguy63
Yes you can run a layout with 2 wires and nothing soldered. Just about everyone does that with their under the Christmas tree layout.
Now as the others have said – down the road – if and when you go DCC you will find out that DCC is much more critical with good electrical connections.
Many have found this out after the fact as they built their layout and tested it with DC and then decided to go to DCC. Nothing worked. Engines stalled all of the time, sound engines had scratchy sounds, unexplained shorts or runaways.
And they tried to blame the manufacturer of the DCC system! The DCC mfg were producing junk!
I helped one club figure out why their layout (which had been working ok for 10 years with DC and was working barely with DCC for a year or two) needed rewired. They had wire sizes for the buss wires from #20 to #14 and the drop wires were few and far between. They were connected to the buss wires with Wire nuts Scotch locks and some were just twisted together.
They kept telling me that it worked for years this way, why wouldn’t it now. I had to explain to them that while the wire could carry the current needed to run the trains, it was the signal that was getting lost in the noise generated by the engines running, resistance of the wire and the poor wire connections caused from years of corrosion. Several members stated that the layout had not really operated all that well with DC.
Well once they decided to rewire the layout properly (which was a lot of work) they could not believe how everything smoothed out!
I decided yearly on that I did not want a maintenance nightmare with my
When you add DCC to the equation, with its high frequency square wave AC signal, the rules change. Inadequate feeder wires, rail resistance, and corrosion within the rail joiners can cause a loss of control and either runaway trains or dead spots.
I’d rather go to the trouble of installing what some consider to be “overkill” feeder wires now than having to go back in a few years and try to add them after buildings and scenery are in the way.
I have just started wiring and laying my track and have placed feeder wires on each segment of a staging yard, however, they are spaced a bit farther than every 3 feet. I understand both sides of the feeder wire spaced every 3 feet debate, and have come to the conclusion that it is better to err on the side of more is better, than the less is more theory.
The feeder wire every 3 feet camp works to overcome the failed track joiner connections issue by incorporating electrical connections to every piece of track. This theory also helps to prevent the need to re-wire track down the road when scenery is in place. I understand the reasoning behind this technique, it makes sense to me, while it may be overkill, and it does reduce or eliminate the possibility of dropped electrical connections on sections of track.
Now what I have learned from the sage advice of the “been there and done that” and “learn from others mistakes” group, and Alan Gartner’s Wiring for DCC it is suggested that a feeder be placed about every 10 feet or so for Code 100 track and every 6 feet for Code 83 and lower sized track. And for weathered rail the suggestion is to solder or wire every section of track. Again this is a suggestion. Now the recommendation is a basic rule of thumb, that every piece of track should be soldered to something, either another piece of track or preferably a feeder. Makes sense to me that to ensure constant electrical connectivity a combination of soldered joiners and feeders will maintain a higher level of performance over the long haul. These suggestions and recommendations will also reduce the number of possible "po
Just one other thing to think about on this issue. I work in industrial maintenance in an auto manufacturing plant. On any wiring we do, we use a very simple method for planning ahead. Let’s say for example that whatever it is we are wiring in needs #18 wire according to the codes and specs (Ugly’s book or other source). When we run the wire, we will go one gauge larger to leave room for the future. In this example we would wire using #16. It costs very little more at the “front end”, but in the future you will have capacity for better/more usage and upgrades. Over the Christmas shutdown we added some equipment at one end of a major line in our shop. While we did have to add some wiring, we were able to reuse most of the existing because it was capable of handling the requirements of more and newer equipment.
I do the same thing when working on a house, go a little bigger than you “need” and you won’t have to worry about it in the future. Most of my house wiring is #12, specs call for #14. The rest is all larger stuff like the well pump, the water heater, etc. I have never had a wiring related problem and don’t have to worry if I decide to add an outlet (or maybe a siding to put into train terms) to an existing circuit. I would always tell anyone to spend the money on the structural and electrical stuff early and prevent future hassles. While you may not “need” it, it sure is nice to know that you are covered on the important stuff.
I agree. Add paint, ballast, weathering, and DCC, and now you’re really tempting fate unless every ection of rail has a direct connection to a feeder. One way to reduce the number of feeder drops is to solder 2 or more lengths of rail together and run one set of feeders to that section. For example, I may solder a set of terminal joiners between two 30" lengths of flextrack. But, my track never goes more than 5-6 feet without feeders, and depending on the distribution of turnouts, sometimes feeders are less than a foot apart.
Think of it as insurance. At soem point one or more of your mechanical connections (and probably even a soldered one) will fail.
Soldering a drop to every track joint is wasteful overkill, electrically. You accomplish the same thing by soldering a drop to every other rail joint such that the rail on either side of the drop is hardwired. The price of doing this is reliance on a single solder joint for direct electrical feed, but…it becomes immediately obvious where the problem is should one ever develop.
The upside is an expansion joint every six feet.
If, on the other hand, multiple feeds to a section of track are unnecessary, then there should be no objection to twisted wire connections under the table, taped and unsoldered. If this idea makes you shudder, and it should, then you can’t advocate electrical feeds that depend on mechanical joiner connections to power the whole layout.
The key is balance.
Over the years I have also notice a lot of block wiring overkill as well as other wiring overkill.
As far as DCC Digi Traxx suggest a feeder wire every 6-8 foot which sounds reasonable to me.
Now,You can operate a 4X8 foot layout with 2 wires-from the power pack to the track-just ask any 10 year old kid or adult with their first 4x8 loop layout. Heck most use snap track and runs their trains for hours trouble free.Even I have built small industrial switching layouts using snap track and as I recall one early 4 x 8 foot layout.
As far as soldering the rail joints the only time I have done that is on curves made from flex track.
Installing feeders in every section of track is certainly necessary for a trouble-free electrical system if you don’t know how to install rail joiners properly. If you do know how to install rail joiners properly, then I think the claims of probable future problems are rather overstated by most folks.
Parts of my layout were constructed over seven years ago (progress is very slow!). Those sections spent some time in a non-climate controlled storage room (very cold and dry to very hot and humid), plus a couple of years in the basement before I controlled the humidity there. Prior to climate-controlling the basement I had some problems with trackwork kinking due to benchwork expansion / contraction from humidity swings. I average a set of feeders every 15 feet or so - every four to five sections of track. I’ve never had a problem with electrical continuity in the rails.
I’m not saying no one has ever had problems if they properly install the rail joiners - that would be every bit as arrogant as flatly claiming one WILL have problems if one doesn’t attach feeders to every separate piece of rail on the layout. Whatever may be - my method has worked very well for me, now and on previous layouts.
Here’s how I install joiners to ensurecontinuing good electrical transmission: 1. Clean the rail ends on the top and bottom of the rail base (inside and outside the web on the top of the base) using a cutoff wheel running at low speed in a variable-speed Dremel. At the same time, put very small bevels on the ends of the rail base. 2. Install never-before used rail joiners on one section of track, then align the mating section both horizontally and vertically, and slide it into place against the first piece. Re-using a rail joiner practically guarantees a looser grip on the rails, where paint, dust and debris can collect and slowly inhibit electrical flow. Wiggling the rail joiner around excessively to start it on the rail does the same thing. I wiggl
I have to agree with you on the nuclear bomb-proof bench work!
Having been involved in building layouts in everything from dessicated desert to tropical beachfront venues, here’s the system I have come to prefer:
Install insulated joiners wherever your control system, signaling plan or good sense indicates.
Use uninsulated rail joiners to assure rail-end alignment.
Solder one feeder to the rail somewhere between each pair of insulated rail joiners.
Solder a jumper (a little omega-shaped bit of wire) around each uninsulated rail joiner. Don’t solder the joiners themselves.
Installed this way my electrical distribution has always been bulletproof, and I use a lot less wire than the ‘direct wire every piece of track’ folks. (In case you haven’t priced any lately, wire isn’t cheap.)
Just my [2c]. Feel free to disagree.
Chuck (modeling Central Japan in September, 1964 - MZL, analog DC)
I have never been sorry where I overbuilt, wish I could say the same for where I hadn’t.
Enjoy
Paul
[#ditto]
Over-engineering is the way to go. :slight_smile:
After all of these contributions, it appears to me that the joiners are the weak link. My experience is that joiners should…should…do a good job of maintaining contact with each rail, even when they are weathered. The fact is, they don’t. They don’t because they get stressed upon installation, or stressed when they are subjected to the rigours of 16 oz locomotives passing overhead. No matter how well one creates the tracks’ roadbed, the various easements and supervelevations that we insist are necessary at scale mean torsion and differential support for the rails across from one another.
My name is Crandell, and I don’t lay rail very well. But, I’m getting better. Until I am highly skilled, I will continue to rely on soldered feeders to cover pairs of 3’ sections of flextrack. One feeder every 6’ is eminently sensible, and saves a lot of time in cutting wire, stripping, drilling tiny holes, etc. In the meantime, one feeder/joiner pair is the way to go for me. Keeps it all manageable.
Myth? Yes and no.
Case 1: My temorary simply 4x8 oval. Used bachmann EZ-Track. 22" radius curves at each end plus however many straights I could fit in the 4x8 space. Two sets of feeders, equally spaced around the loop. DC and DCC, locos slowed when they were the furthest from the feeders. ANd this was new EZ Track, it hadn’t been used over and over again, which usually results in loose joiners.
Case 2: my permanent layout. 8x12, double tracked loop plus sidings and a yard. As soon as I completed the track for the first loop, I attached ONE pair of feeders to my Zephyr to test run it and had NO problems with locos slowing even all the way around the other side of the layout. Track was Atlas Code 83 flex and Atlas Code 83 turnouts.
Result: inconclusive. Track type and quality plays a big part in the whole thing, obviously.
