There have been some excellent points made by the responders to this thread. What it all breaks down to in my mind is this:
What is the talent level of the modeler, mechanically for benchwork and electrically for wiring?
How much money does the modeler have to do the layout at the onset?
What are the characteristics of the modeler ( rivet counter, moderate, or "good enough for me attitude ) ?
What is the “patience” level of the modeler.
What is the health level of the modeler ( can they crawl around, get under benches etc. or are their knees and back so bad they can’t do these tasks easily ) ?
Do they have help, or will this be a one man band?
I have a layout that we set up every Christmas of a large village, on 6 tables of 4’X4’ each. They are made of 3/4" plywood with 2x3 supports at each end to join sections of 4x4 tables. I have to get up on these tables to set the tracks up first before the wife sets her buildings on the tables. So to answer one of the originator of this thread’s questions, because it needs to hold my 185 pounds! That’s the constructions side.
Now for the electrical side of the question. I have been setting up this layout for 20 years. It uses EZ Track, about 75 linear feet up grades, around curves, over the river and through the woods to grandmothers house. I have ONE feeder to the tracks (DC). The system gets stored in cardboards boxes in the basement level of the house for 11 months through humidity of summer, and winter dryness. The train runs
To start off with, there is nothing wrong with over engineering. Up until recently the phone system in the U.S.A. was over engineered to handle everything except for Mother’s Day. That is why one could always get a dial tone. This same thing is true for Model Railroads. The more over engineered things are the less likely problems will occur in the future.
As an opposite example, for Christmas I ran the trains around the tree and the room(sort of a infolded figure 8), so the outside track loop was probably 25x16. Fn3 scale on mostly LBG track. Cheepo Bachmann 4-6-0 and Kalamazoo 4-4-0 locomotives. DCC powered connected to the track with standard 22 gauge solid bell wire. I didn’t even “connect” the wire to the track. I just shoved the wires into a railjoiner and pressed the track together. It ran just fine, almost constantly, for the three holiday weeks. The only issue was children and dogs knocking the cars off and bumping the track where it crossed the entrance to the room. Would I ever wire a permanent layout this way - no. Does this bust an overengineering myth, no. What it does show is that what will work in this one specific case vs. what we actually do to attempt to account for generic cases.
Feeders at every joint is definitely overkill. I do every other joint which means every section of rail is fed directly from a feeder and the loco is never more than 3 feet from the nearest feeder. Even this much wiring might be more than necessary for reliable running but it doesn’t hurt and requires a small investment of time and money to be on the safe side. During initial construction and testing, I hadn’t soldered all the feeder wires yet my test runs ran with few problems. Every once in a while I encountered a railjoiner that was less than snug and I would occasionally get a stall. With every other joint now wired, I don’t have to worry if a rail joiner works its way loose.
My layout is DC and DCC. It’s divided into 16 blocks with feeders going to each block. Each set of feeders goes back to it’s own DPDT switch and all the switches are connected the power sources (DC and DCC). Flip a switch up, that block is DCC, flip it down, that block is DC. I haven’t had any problems with this arrangement.
What I could never understand is why modelers always want to shortcut the 3 most important things when building a layout.
Benchwork
Trackwork
Electrical wiring
I was always told these are the foundation of the model railroad.
I have been in model railroading for over 40 years now and have visited hundreds of layouts. It is amazing how many of those layouts have problems with one or more of those three.
Benchwork while it does not have to built like house it still has to hold the track work level without buckling and causing track problems.
I have seen track laid on ¼” plywood and the risers were 3 feet apart. When the engine crossed over that part the roadbed would actually move. And then others used the sticky tar based roadbed and the track kept coming loose, causing all sorts of kinks.
And the Trackwork, is it so hard to actually get down and site the rail jointers to see if there might be a kink both vertical and horizontal. Apparently it is as almost 90% of the layouts have kinks in the Trackwork. And this includes those that have been in the model magazines. Now I know my layout has a few but as I find them I spend the time getting them straightened out.
You know there is a problem when the owner of the layout waits for the train to pass a certain place so he can reach out and rerail the engine as it goes by or a car derails at the exact same place time after time but not to worry as it jumps back on just down the track, go figure!
And the electrical, this is where most of the arguments are. If the train makes it around the layout
Enough is enough at some point. Im planning a feeder every other section so all track gets power multipule ways.
Rail joiners are never enough.
In the Hobby Shop we just finished each switch with up to 6 additional wires running off the Torquises so that each frog will be live etc… We ran a train that was rather “Picky” and after following with a file and removing bad sections of rail, it ran flawlessly forwards and backwards. It would be years before we have electrical problems on that line.
I find it interesting that Modulars dont get thier fair share of feeders. There is ALOT of bus and feeders going on in EACH section.
If a day ever arrives that we set up track, attach two rails and all the joints weld into one leaving no gaps unless needed at specific spots then that will be a day copper prices will fall.
Until then, the availible wire stock is growing in advance of construction.
Safety Valve,See this old yard layout? No blocks,no feeders,no soldered joints just 2 wires from the power pack powering the whole thing.The thing to remember with rail joiners is be sure they are tight on the rail…This may require squeezing the joiner with pliers.
It just seems like if you add more feeders, you’re less likely to have troubles. I think that’s all people are saying. Sure, you can get away with just two, but then you’ve got what we call in the military “a single point of failure.” They build redundant systems into airplanes and spacecraft; seems like a good idea for a layout, too. Especially a guy like me whose track-laying skills are a bit brutish…[:)]
The main point from everyone seems to be that their way is the best way. Maybe a little indication also that you need more feeders for DCC, but I know that’s impossible because DCC is vastly superior in every way.
I think I will just keep on doing what works for me too.
From my experience, most rail joints fail in conductivity because of poor track installation at those points, not because of any inherent fault with the rail joiners. By the way, you won’t get failure issues from corrosion at the rail joiners like some have with Scotch-lok and similar connectors, because there’s no galvanic reaction unless you use the wrong type of rail joiners.
Installing feeders on every section of track to avoid (or overcome) continuity problems at the rail joiner is simply over-building in one way to compensate for less-than-adequate work in another, IMO. But hey, that’s just my view - to each his or her own. Installing a bazillion feeders isn’t my idea of fun, so I’m extra careful when I install the rail joiners, which is why I’ve NEVER had one fail electrically (or otherwise) since I started doing it the way I described earlier.
There is another important reason to use more track feeders other than worrying about ,or trying to compensate for, track laying skills. It is very important for DCC operation, and that is “resistance” per linear foot. As you load down the track system with more and more equipment drawing current, the voltage drops begin to add up, and that can spell Trouble.
We spend thousands of dollars on our rolling stock and locomotives, isn’t it logical to spend the time and money to wire our layouts to ensure trouble free operation?
After reading many of the replies above, and “should haves”, it reminded me of an old saying that I loved in industry: “It is the duty of all good engineers to anticipate all possible problems before they occur, and to have ready corrective actions when and if something goes wrong. However, it is very difficult to remind oneself, that the original objective was to drain the swamp, when your up to your neck in alligators”. ( Some words have been changed to protect younger readers from industrial slang ).
My name is Jim, and I don’t lay rail very well, but I lay rail better than I paint it, and ballast it, and do scenery, and … But, I’m getting better.
I’m hoping that the layout I am building will operate well enough that I don’t have to rebuild it in the foreseable future. I fiddled with rail joiners, squeezing them in a vice, etc. but I could not convince myself they were tight enough to work forever. I did discover that soldering feeders onto every track section is really not too hard or time consuming, and I discovered that I enjoy doing it! Now I have a layout with lots of track sections joined by unsoldered joiners with a forest of feeders dangling below the table. I hooked up ONE SET of feeders to my DCC system. I’ll get to the rest, and a bus eventually. Oh, I do have one piece of track which has NO soldered connections: it’s a 25 degree crossing, and I just couldn’t figure out a good way to put feeders on it. It does have 4 sets of rail joiners though. My feeders are 20 gauge stranded wire, and will eventually solder them to a 14 gauge solid bus (Romex) not more than 24 inches from the track.
Wanna hear about my turnouts? I soldered one set of feeders to each turnout, AND soldered 30 gauge stranded wire loops between each moveable point rail and it’s stock rail. I’m not expecting any electrical problems with them! I did NOT attempt to power the frogs (these are Atlas customline with insulated but powerable frogs). I’ll do that in the future if I find I must.
I have an OLD layout (30 years maybe) and it DID have a rail joiner which had failed to conduct power. Once I found the offending joiner, I slid it back and forth once and it’s been find ever since.
Enjoy YOUR trains! How permanent is YOUR layout? Will it be a source of frustration if it isn’t perfect forever, or are YOU willing to perform troubleshooting and maintenan
You make an excellent point - one I’d forgotten when I responded to the original post. To each his own. This may sound snide, but I mean it sincerely: shame on me for suggesting my way was the right way. Whatever I know about layout wiring I learnt from my father. He was an electrician/fine instrument maker and, if you can believe it, even more of a perfectionist than I.
It’s too easy to forget that everyone comes into the hobby with different experience and ways of tackling problems. I’ll probably continue using feeder wires on every three-foot section because that’s the way I was taught and because I enjoy soldering and electrical work generally. I’m also really lazy; so, nothing spalts my bricks more than having to go back and correct earlier mistakes.
I am not going to pass judgement on the “correct” way to wire rail sections or the “correct” wire gauge. Here is what works for me with no maintenance. I use DCC. My bus is 14 gauge stranded wires. Runs are as long as 90 feet from the power source. I use about 4" of 22 gauge solid wire from the rails and solder to 14 gauge stranded wire. The 14 gauge wire is then connected to the bus using suitcase connectors. All rails are soldered. I heat the rail until the solder is “sucked” into the rail joiner. Feeder wires are spaced between blocks. Yes, I have blocks for detection and singnaling purposes. I have check voltages from one end of the layout to the other and there is no more than 0.2 volts difference in the meter readings. Engines run smoothly over the entire layout. So, do I overkill? I don’t know. I do know that my railroad runs very well with the standards I use.
Hum, more feeders needed. Boy I have heard that before! I am new to this hobby and was told when my DC MRC 6200 was not doing what it should the main wires where to small (from 6200) to blocks where to small and I needed to up grade the sizes of the feeders. I did, results was the MRC 6200 was junk! I replaced it with a smaller MRC 9500 and ever thing worked as it should.
I have two main lines, B is now DCC with a cheap and under powered E-Z with only 1 amp. B has 7 feeders and is around 95 feet. One of the reason I had not went DCC sooner is fear of more wiring. If I have done the math right there is only 1 feeder per 13.57 feet, far short thand 1 per 3 feet.
So far there has been no problem, yes the joints I attache (spell check) the feeders are solder but that is it.
My track laying skills are much better that what I came to this site with, thanks to the help i have gotton. But, like many things I have been told you have to find what works for you. Start cheap and add as you need to get what you want.
You don’t need to spend $12.00 + for ready to run rolling stock, you don’t have to have 22" turns to run steam, be Bob Villa to bulid a bench, and don’t need feeders ever section of track.
As in almost every aspect of this hobby, what is acceptable to some is totally inadequate for another. There is no absolute right way to wire a layout. Some, like myself find the DCC/Electrical aspect to be a very interesting and stimulating part of the hobby. There is nothing that I enjoy more than tinkering with a soldering iron and getting things to work. Every single piece of my track is soldered to something. It may be an adjacent piece of flextrack or a pair of feeders. At no point on my layout is electrical continuity dependent on a press fit rail joiner. This is what works for me, and IMO this will significantly add to the long term reliability of my layout. For me the attachment of feeder wires is neither a chore or a great expense. (You can get a lot of color coded feeders out of mis-cut lengths of thermostat wire). If someone else has great reliability and success with a layout connected with 2 wires from the transformer then great! I guarantee that there is someone who thinks my approach to the wiring is overkill. It is just as likely that they have a greater obsession with another aspect of the hobby that is of less interest to me.
I don’t think anyone is saying that their method is “The Right One” simply that it is the one that works for them.
There is this - if all you “feeder fiends” are overdoing it, there’s no serious downside. If I’m wrong, in five or ten years I’ll be crawling around on and under the layout adding feeders everywhere. BIG downside! Still, I’m bull-headed enough to take that risk! [:D] I do run 12-gauge busses, so the main distribution network is there if I have to add more taps.
Okay, it sounds like everyone is using flex track so I think I’m the oddball here as I’m using sectional track (Atlas True Track NS code 83 in 9" long sections with regular rail joiners).
I’m using 5 amp DCC with 130’ of track and 3 sets of feeders roughly equally spaced. It’s been running very well for about a year. I’ve had some discussion on this with Jeffrey Wimberley but now I’m wondering about the future?
How do you prevent electrical conductivity problems with sectional track? Please don’t say don’t use it, unless that’s the only answer.
I might also point out that all my track is loose-laid on top of foam. No glue. It just floats. I did this at first thinking I may want to move things around but I’m happy with the arrangement and won’t be moving much. With the plastic built-in roadbed, everything locks together well and doesn’t move, except for possible expansion/contraction. Painting the foam and adding scenery tends to hold the track in place as well.
Simon,For me I prefer the KISS method…Even when I do have blocks I use the Atlas controller with selectors…To my mind that is goof proof KISS method at its best because one wire goes to one block.[:D]
