Does anyone out there own a set of N scale Bachmann/Spectrum F-7 units, and if so, what do you think of them ?.
TL
TL
i’ve got one of the f7a&b sets. they run good although the front pilot on the a unit is too low and catches on uneven rail joints and stops. i’ll have to shim up the body shell as it is a little low in the front. i would buy another set if they had different road numbers. i’m going to put in dcc and i haven’t changed the couplers yet.
The couplers definatly need to be changed. The Spectrum F7 isnt the smoothest running of the F7s for sure. But its not a bad unit overall
