N scale DC to DCC
Im just starting out on a lay out but have all the wiring in under the hard shell. How hard is it to convert to DCC? I also only have one loco so its not like I have to replace a bunch of locos.
thanks
Dutch
your existing wiring should be fine for dcc. i started my latest layout 2 years ago with the idea of going to dcc so i only wired for a pair of 14awg feeders with no block controls except in my engine service area for non decoder equiped locos until i can change them over. i went with digitrax super empire builder that is radio equiped. two wires go to the rails and two wires come from the power supply. hookup takes about 5-10 min. if you have wired for block control with toggle or slide switches you just leave all the switches on. just don’t leave a non decoder loco on a powered track. i did that with an atlas n scale gp7 and the motor got so warm the armature wouldn’t turn when i wanted it to move. when it cooled down it was ok.
Converting to DCC at this point amounts to buying a DCC system, putting a decoder into your loco, and connecting the two power out feeds of the DCC system to the track. Presto, DCC!
You’d be amazed how easy it is…simply follow instructions with your set and that’s all about it.Your loco may be a problem if of older design as it may not be easy to retrofit.
