N scale double main lines
I am in the process of building an N scale layout and am wanting a double line main on parts of the layout. Some places the two tracks will run paralle with each other and I would like to know what is a safe distance for them to be from one another? Thanks, Mike
1 and 1/8th inch to 1 and 1/4 inch is usually good. On a straightaway you can get closer (like an inch), but you may have trouble reaching between the tracks to put a car on the rails if the other track is occupied.
From http://www.nmra.org/
S-8 Track Centers
S-8
This STANDARD lists Track Center Distances and provides for Side Clearances required for various curvatures with three size categories of models.
Class II
Includes small four-wheel truck diesels, geared and other small steam locomotives with short end overhangs typical of old-time, logging and branch lines and equivalent rolling stock.
Class I
Includes longer steam locomotives typically with two-wheel trailing trucks, larger four and six-wheel truck diesels and equivalent rolling stock.
Class Ia
Includes the largest steam locomotives with four-wheel trailing trucks, articulated locomotives, those with rigid wheelbases in excess of 20 feet, full length passenger cars and other long rolling stock.
Curvature Degrees
M(*)
0
5
10
15
20
25
30
35
40
45
Radius - Prototype
Tang.
1146
574
383
288
231
193
166
146
131
ā€˜N’ Scale
Radius-Inches
Tang.
86
43
29
21 1
