N Scale Inclines
I am starting to plan for an N-scale layout - I have an HO layout in the family room but the N-scale will be adjacent to my workshop. I understand the incline rates for HO (ie 2% in 100 inches = 2 inch rise), but what about N-scale. I presume it would be different since everything is just smaller but I have not found any reference to this at the NMRA standards site.
I want to have a raised portion at one end which clears the track and any consists below but I need to plan for how long an incline I will need.
Thoughts?
The math for a grade percentage is the same for any scale because it is a ratio, not a dimension.
A 2% grade in N is the same as HO.
Grade is grade regardless of scale, you just have to climb only 1/2 the distance being 1/2 the size of HO.
The grade is the same regardless of scale. The only thing that changes is the scale.
Let’s look at a 2% grade:
  • Full (1:1) scale. 10 meters long. Rise, 200mm.
  • HOj (1:80) scale. 800 meters long. Rise, 16 meters.
  • HO (1:87.1) scale. 2,857 feet long. Rise, 57 feet.
  • N (1:160) scale. 1600 meters long. Rise, 32 meters.
  • N (1:160) scale. 5246 feet long. Rise 105 feet.
If you laid G-gauge, Sn3, HOe or Z scale track on that 10 meters of roadbed, the grade would still be the same. Only the scale length and scale rise would be different.
Thanx for that - I had overelooked the fact that it is really a ratio.
Barry
Thanx … I thought that I would not have to have as long an incline as with HO - was a bit confused.
Thanx again … Barry
Thanx … really helps to know that info. Put things into perspective.
Barry
