I’ve researched the archives as best I can but still have questions about whether I should go HO or N.
At this point I have no equipment. Eyesight is generally good although I wear glasses. Dexterity is fine. Age 59. I have space in the basement although I’d be starting around 4 X 8 or maybe 6 X 10, could start with either.
Don’t even have a layout in mind although I’m thinking of mountains, tressels, tunnels, doing some ups and downs as part of it plus perhaps switch yard as part. Running at least two locos, MUCH prefer steam. Don’t care about fine details at all. Have never done any proto stuff, only had “table top” sets in HO and O (wish I had the the old lionel 1955 set still).
Have lots of questions regardless. Should I start with DCC (which manufacturer, is there any difference?). Should I buy all parts or should I get a kit of some sort? I figure I’ll build a table but, I’m not sure of how to proceed. Do I plan out what my track plan is all in advance? Do I have to pick the “era”, in advance? I’m into the technical aspects, somewhat into building, less so into modeling although I’m inerested in learning “some”.
Do I pick a supplier and stick with it for track, rolling stock etc. Or, just track or ??? Is there any difference? What about flex track versus snap track. I remember the days when you bought individual brass rails and used miniature ralroad spikes with a needle noise set of pliers and carefully measured out your own gauge as you built up the tracks.
If I had my ultimate druthers, I’d looked at WW II steam engines and model those types of trains with corresponding rolling stock and military vehicles. BUT, I’m also thinking of doing some kind of coal facili
