N&W "J" Class decals?
Does anyone have a source for N&W “J” Class locomotive & Tender decals (like the 611) in HO scale? I did a quick search but came up short.
-Thanks,
-B in B
A correct set of N&W streamlined steam engine decals used to be available from Roanoke Rails. They are not available at this time. They had correctly sized and spaced lettering and stripes.
Champ makes a set that is good enough for the J & K-2 streamliners. They also have the correct stripes as another set. You will have to curve the stripes on the forward ends of the running board skirts and at the firebox but it isn’t that hard to do. Get the dulux gold sets and not the bronze gold ones.
Micro Scale has an N&W steam set but I think the spacing is off for all 22,000 gallon tenders like the J.
Hopefully the N&WHS or Shell Scale will make the Roanoke Rails sets available someday… SOON???
Roger Huber
What is the problem you mention with the spacing of the microscale decals? [8D]
I’ll have to check but I think the MS sets have the lettering spaced too close.
Roger Huber
