Name this Part!
Quick & stupid question. What’s the name for the part underneath the cab on a 1666 or 2026 or probably a couple of other steam engines that holds the drawbar in place? It extends down on either side of the casting underneath the cab and has a flat piece that goes across the back of the shell. Creates an opening and sort of a shelf that the drawbar sits on. Thanks for any help on this.
I believe your talking about the rear truck assembly
Larry
Rear truck bracket part # 1110-9
On the locomotives that you mention, that feature is not a separate part (as it is on the Scout locomotives), but is part of the boiler casting. So I think you are probably looking for the name used in prototype locomotives. However, they don’t have anything like it. Instead, there is a transverse beam (the “footplate”) with a socket (the “drawhead”) in the middle for a vertical pin and a heavy-duty link (the “drawbar”) pivoting on it, to connect with the tender. There is also a “buffer” or “chafing plate” for backing up. Sometimes this stuff is put on the frame of a trailing truck instead, which makes it a little more like the Lionel models, but still without the “shelf”. Obviously the prototypes didn’t have to contend with the tight curves that the Lionel locomotives do.
Thanks for the responses. This is NOT a separate assembly. Sometimes it is, as in the case of the 736. Here it is part of the boiler shell casting. For a lack of a better term, it’s probably a “drawbar shelf” as I am sure this does not exist on a prototype. I’m just looking for the correct term so when I post a question about it I don’t refer to it as “you know, that thing underneath the cab that the drawbar slides across”. I told you this was a stupid question.
thanks again,
Jeff
Thanks Bob! I know you know what I’m talking about, just trying to come up with a name for it.
Jeff
I kinda like “transverse beam”
