This poster for HSR or at least HrSR has long been a supporter. However---- The source of power for the HSR electricity needs examining. The electric grid collapse in Texas makes it clear that the Texas, eastern and western grids are vulnerable to overloads. That fact has often been cited by others in the electric power industry. HSR might be subject to shutdowns or too high price charges due to inability to supply power where needed… The demand charges that industries and businesses are subject to may be cost prohibitive. NARP’s statement of using renewable power for HSR just does not compute. Amtrak is very fortunate that it receives much of its electric power from the Safe Harbor hydro dam. That facility uses hydro power that can be instantly increased when demand warrants. That is because the hydro generators are always turning at the required Hertz. and all it takes is for water to be directed onto the turbine. How many locations in the USA can get the same peaking power needed for the electric HSR trains ? I do not believe that is the present state of the USA power grids. That is probably one reason freight RRs have not embraced CAT electric loco power .
I sat in on the conference call at the Federal Level with Congressperson Van Taylor, FEMA, ERCOT, etc that discussed what happened. First I have no idea what you mean by Eastern and Western grids, Texas has only one grid that serves primarily Texas. Second there is plenty of reserve capacity, the problem that led to overload conditions was lack of winterization and parts of the grid, specifically Natural Gas Fields feeding Natural Gas Power Plants were classified as non-essential infrastructure. So when ERCOT gave the order to shut down power to non-essential infrastructure, power was shut down to several fuel sources throughout the state that led to Power Plants going offline at peak demand which greatly exacerbated the situation. Additiona
It’s pretty clear to me that he meant the Eastern Interconnection, the Western Interconnection, and the separate Texas Interconnection. (He might have added the Quebec and Alaska Interconnections, but those don’t factor into HSR…)
Yes, the point about enhanced demand for vehicle charging factors in here, probably to a greater future extent than rail demand. Any emphasis on increasing use of renewables that does not involve substantial use of renewable-fueled peak and baseline combustion stations is going to involve enormous amounts of storage, which has associated cost, maintenance, and lifetime concerns. Watch that buck continue to be passed until someone subsidizes or underwrites it.
The other thing of course is the presumption HSR systems would draw exclusively from the consumer grid without supplimentation. That would have specific disaster recovery repercussions on the Dallas to Houston route and I could not see that being approved by the Feds as OK from a safety perspective. I don’t know how the NEC is powered but I suspect it has it’s own power supplimentation as well.
