NCE CP6 6-Zone Circuit Protector
I’m buying an NCE CP6 6-Zone Circuit Protector. It uses light bulbs to protect up to 6 power districts on my relatively small 8-ft x 8-ft HO layout. My question - should I mount the circuit protector where it is visible so when a short occurs I’ll see the illuminated light indicating the short OR mount it under the table where all the wiring is located? Hopefully, one or more of you already have experience with this and can help me. Thanx.
Not worth it, especially for an 8x8.
It only protects 1 leg and comes with 1 amp current limiters on each. If you get a back feed from an outside power source you can still cook your booster.
You can do the same thing yourself cheaper and with a higher amp rating using 1156 stop light bulb from your local automotive shop. Put one on each leg.
http://cs.trains.com/trccs/forums/t/124210.aspx
Below is a link to some wiring suggestions. Store all links that interest you.
http://www.wiringfordcc.com/track_2.htm
The CP6 uses what are called Festoon bulbs. They come in different ratings for different current requirements.
http://tinyurl.com/26vpsda
Some people only use DCC circuit breakers.
To answer your question, yes mount it where you can see the light come on when there is a short.
Larry
Thank you to all of you who replied. Following up on your suggestions and doing further research, I’ve decided to purchase a PSX DCC Circuit Breaker from Tony’s Train Exchange. Yes, it’s more money but it will protect my investment in my NCE Power Cab and decoders. Thank you again.
P.S. This is why I love these forums. They keep us all on track - pun intended!
