I seem to be having problems with a few of my switcher engines that have NCE decoders. I have 2 of the older Atlas (Rocco) S-2’s and 2 of the Proto 2000 SW-9’s. I have the NCE ATL-S4SR decoders installed in the Atlas S-2’s and the NCE P2K-SW9SR decoders installed in my Proto 2000 SW-9’s.
The problem I seem to be having is that 1 of each type of engine I have, I can’t seem to program the Engines / Decoders using Decoder Pro.
I will put one of the Atlas S-2’s on the track and start up the software and it will locate and identify the decoder and program perfectly. I then put the second S-2 on the same track and the software will find and identify the decoder, but says that the decoder is not responding to any other kinds of programming. I have the exact same problem with my 2 Proto 2000 SW-9’s. The first one will program perfectly and the second one will not.
I can program each of the “suspect” engines using my Prodigy Advanced to accept a 4 digit address, but that’s all. Both engines will run on the club layout, but run erratically. After a few minutes of running, they will not respond to throttle imputes or Emergency Stop. Sometimes they even dump the 4 digit address and will only respond to 0003. For the life of me, I can’t seem to figure out what’s going on with these 2 engines / decoders and why the other 2 I have work perfectly.
Is there something I’m doing wrong? Is this common with NCE decoders? I have almost 70 other engines, most with Digitrax decoders and have never had these kinds of issues before.
