NCE Doesn't Run
Well I tried testing out my new NCE starter system and nothing is happening. I tried both my Atlas DCC ready Trainmaster with a DH123P decoder and I tried my bluebox Athearn GP-60 with a DH123AT decoder and both don’t go. The DCC fires up and I tried selecting Loco 3 (not 03) and still nothing in both directions and no lighting. I went ahead and tried a 3 ft piece of test track and still nothing. My main table has all the feeders…etc…and has been running fine with straight DC so the wiring doesn’t seem to be the problem. I re-checked the decoders which seem to be fine…the Atlas you would have thought would run with a plug and go decoder. Any ideas…? Is there a way I can check voltages? DC I know, DCC I’m still learning. The NCE troubleshooting section doesn’t say much and NCE Customer Service isn’t in until Weds. for holidays. The back of the Powercab controller interestingly enough has a compartment for double “A” batteries yet no connectors and the book doesn’t mention anything about this. Thanks Steve
Steve,
Make sure your flat cord that plugs into your powercab is plugged into the left side of the panel. The coiled cord won’t work with the Powercab either. This is an easy mistake to make. It’s easy to get it upside down when its not mounted. The Powercab will fire up if its plugged into the right side but the panels red led will not light. If it is lit your OK to go.
I think the battery compartment has something to do with the wireless version.
SB
I did make sure the wires were placed correctly and using the flat wire on left side…I am getting a red “go” light, but still no train movement.
Yes. Disconnect the two wires that you have going from the plug on the back of the PCP to the track from the track. Then make sure that you have these same two wires connected properly to the plug that connects them to the PCP. Then make sure that you have the plug plugged in properly to the PCP.
Then set your electrical meter to one of the AC voltage scales that will allow you to read up to 20 volts AC. Connect the meter leads to the two wires that you just disconnected and see what voltage you have.
Did you select a locomotive on the Power Cab (maybe someone has programed the decoder to operate on a cab number) {number on the side of the locomtive}.
Steve.
Your volt meter should read about 13.5 volts or more if there is track power. Putting a 18 volt bulb across the rails will also tell. If there is power then do this. When the red LED is lit on the panel that means power is being sent out of the power cab.
Using the short piece of track with the power cab hooked up to it. Put the loco with the decoder on the track and press the prog/esc key 4 times and hit enter and see if it detects a decoder.
Pete
All plugs functional, hooked up voltmeter to track and read a/c voltage…getting 14.8V. Hit esc key 4 times to get to program track and selected “1”…system then read: “main off - can not read cv.” I tried this on the Atlas DC ready loco…any ideas? I did make sure to check the loco selected at “3, same as decoder.” Thanks
If you got the message “can not read cv”, the system is not seeing the decoder. When it gives you that message, what happens if you push the enter button?
Try selecting 03 instead of just 3.
Connect the wires to your 3 foot long test section. Connect the meter across the rails and see if you are reading the 14.8 volts.
Now put the Atlas unit on the same test track and see if you are still reading voltage. If you don’t read any voltage, then there is a short in the engine. If you do still read the same 14.8 volts, then the decoder is not accepting a command from the PowerCab.
Did you do the decoder install yourself with a new decoder? If yes, the decoder should have come with a default address of 3. If someone else installed the decoder, was the decoder programmed with the engine number? If you are not sure of the decoder address you can try to reset the decoder.
You can also remove the loco shell and use your meter to check if the decoder is receiving voltage from the track. And you can probably also check to see if there is voltage between the decoder and the motor. Just be careful poking around to not cause a short across the decoder.
I hit esc X4 and got to “program track”…I selected option “1” STD and this is where I got “no main - can not read cv” at this point I hit enter and nothing happens. I tried putting in different combos of “3” still nothing.
If you know for certain that you have it hooked up in all respects, power is on, and the tracks get normal voltage via the wires, and you know for a fact that the decoder is properly installed and functioning, and if you select address “00”, and do a full CV8 Programming on the Main (or Ops Mode) reset by making its value 8 and hitting enter (or whatever the procedure is with NCE), and nothing happens, no jerk, no blinking engine lights, and it still won’t respond, you are not emitting DCC signals to the rails.
Crandell
I thought I’d try the “unlock” feature to unlock the decoder it said “reading cv15” ran through a bunch of numerics then gave the message “unable to unlock.” Not sure if this is pertinent. I re-checked the decoder in my Atlas…only fits in one way right? I can’t see anything that would warrant a problem. Don’t know about programming anything…just went through the “quick start” to see if it would run and that’s where I’m at.
Hazmat
As for as saying, that the plug in will only plug in one way I’m not so sure. About three years ago I was trying to install a plug an play and I thought some one said that It could be installed back wards an that you would get a light but the decoder would not work. Supposedly the decoder would not be hurt.
Ever since I have only hard wired decoders.
There is something else that gives me trouble. From time to time I have a problem reading a decoder and have found by checking the track plug to the back of the panel receptical, that there is a loose fit. The weight of the wires may disturb the connection.
Something else, my first loco ( Bachmann SW8) by pushing the #6 I believe, twice quickly the loco would not run untill you pushed a # again.
Good luck. [swg]
Lee
Steve,
I get the “cannot read decoder” quite often with the Powercab but it will still let me program and run the locos. Is there a DCC ready loco you could borrow? I have found the two powercabs I have work flawlessly as long as the decoder equipped loco works. I bet your problem is in the decoder’s or decoder installation.
I’ll give the plug a try and maybe reverse it if I can. The loco is DCC ready…I just plugged in the decoder and it should be ready to go. It was an Digitrax DH123P into an HO scale Atlas Trainmaster. I’ll give the plug a try. I’ll let you know if I’m lucky. Thanks!
I tried reversing the plug, no go. It went in about half way and that’s it. Based on the config with the other wires it would munch up against other plugs and would never fit right with the existing wiring. The orignal way the plug was in, it fit perfect. No luck…worked on this all day and I’m just about at my end wits.
If the Power Cab can’t read the decoder it will not run a locomotive or will it program it!
Try a short section of flex track and hook up the Power Cab track output wires to this flex track.! Make sure the track is CLEAN. Now put the locomotive on the flex track. This short section will remove any layout problems( errors)
Try to read the decoder, it should read back the manufactures ID. Digitrax’s number is 129.
If you can’t read the decoder it means the Power Cab is NOT seeing the decoder. Check the wheels to make sure that they are CLEAN. You did not say or I did not read, as to whether this is a new locomotive or one that you have run on DC. I have seen locomotives that would run on DC but will not run with a decoder because of dirt on the wheels.
I have an NCE 5 amp system with a Pro Cab, so I am not familiar with the Power Cab.
However, I would not assume that just because the Power Cab is not able to program the decoder that it is not “seeing” the decoder.
Trying to operate the Power Cab on a short section of test track makes sense. Dirty track or wiring problems or whatever can cause the system to malfunction and not be able to read CV’s including the manufacturer and version.
Also, for what it’s worth, all Digitrax decoders are shipped with CV01 set to 03, not 3.
The difference between the two numbers being that NCE confusing bit that 03 is a ‘long’ address and 3 is a ‘short’ address. RP for default decoder addresses is SHORT address 3.
I did attempt all this on a short section of clean new track at the first sign of problems, no go. I checked a/c voltages on both the layout and on the short piece of track…it read around 14.2V, so there is juice, just not reading the decoder. This is occurring on two engines not just one. The wheels are clean, I made sure of this. The factory setting is 03 though I double checked and re-programmed by hitting "select engine and typing in “3.” The manual says not to use “03” though the display will default to this value. In any event, I tried all sorts of zeros and three combos just to make sure.
