Hi all, I’ve tried to programm the new NCE mini panel using my NCE power cab, but I can’t, Somebody knows how can I do this?
Where are you plugging in the PowerCab? You have to plug it into the mini-panel set-up socket connector. Are you following the instructions: http://www.ncecorporation.com/minipanel/MP-tech%20ref.pdf?
If that doesn’t work, a call to NCE will get you the quickest answer.
