NCE no track power
I have an NCE Power Pro w/ wireless throttle (Procab) I ran a couple of trains 2 nights ago with no problems. Tonight when I tried to run a train I have no track power, main or programing. I have not touched the layout since the last time I ran a train. My power supply is working correctly.The red light by the control bus is on (red) the red status light by the cab bus is not on and the amber ligth for track is on. Any ideas whats wrong or what I need to do?
The 4-pin plug on the left side of the command station may not be seated firmly. Make sure that it is fully seated.
Any possibility that something conductive has fallen across the rails and shorted things out?
A short should produce a slow steady flash of the red Status light on the left side of the command station.
If the 4-pin plug is loose, there will be no power and the Status light will not be lit.
Every once in a while, I will turn on the power to my PH-Pro, and I will get nothing. For whatever the reason, the 4-pin plug is not securely in place.
Just a thought.
The two circuit boards could have separated from one another inside the command station box and, if so, needs to be reseated.
