It has been a while since I used the throttle that came with my NCE system. I can turn it on and operate the layout but I forgot how to turn it OFF!!!
I have gone through the manual and cannot see any reference to turning it on or off.
I know it shuts itself off after a while but those AAA batteries are expensive.
Motley
August 18, 2012, 12:08pm
2
I have the exact same system. I don’t think you can shut off just the throttle, not that I know of.
I just power off the system, it’s plugged into a power strip, and the batteries are fine. I leave the cable attached when not in use.
But you need to get some good quality rechargeable batteries. That’s what I have.
maxman
August 18, 2012, 1:24pm
3
I believe that it is the “expn” button along the bottom. Press it and you get two choices on the screen. I forget what one of them is, but the other is press 1 to turn off. (or maybe press 2…it’s one of the selections!)
expn and 1 does the trick. Thanks Maxman
