Hi Guys,
Quick question. I have 2 pro cabs for my layout. One of the cabs has the green backlight lcd screen on all the time. The other, the light won’t come on at all. Is this a problem?, or do I have to activate it somehow?
Thank You,
Mike
Hi Guys,
Thank You,
Mike
If the defective cab is plugged in the same as the working cab, then you have a bad cab, Happened tome but NCE repaired it for free as I had registered the system when I bought it, even though I had the cab for a couple years. The cab worked but very difficult to read anything.
Your mileage may vary.
Mike,
Are both of these ProCab throttles new? If so then I would give Larry Larsen @ NCE a call.
If this is an older ProCab throttle (e.g. 6 years or >), I seem to recall that NCE didn’t have backlit LCD displays for their ProCabs then. It wasn’t until they released their Power Cab in early '06 that they started using the backlit LCDs.
Wrong !!!
I have had an NCE Power Pro since the mid 1990’s and the ProCab controller has always been back lit.
Thanks for the correction, Elmer.
