I ran into the same problem with Bachmann. I have two of the 2-8-0 Consolidations that I have installed AirWire900 and SoundTraxx Sierra systems into.
As near as I can recall, you must first remove the ash pan cover below the cab. There are two larger Phillips head screws that can then be removed to loosen the rear of the boiler. Somewhere in the front, possibly under the leading truck, is a large Phillips head screw that loosens the front of the boiler.
I discovered that the problem with my first Consolidation, which was dead on arrival, was that two wires had not even been soldered to the circuit board during assembly in China.
I asked Bachmann about the color coding since every wire was either red or black, and their response was that they did not have a wiring schematic available because the factory in China had not provided one; and besides, they seemed to just use whatever color of wire they had on hand.
I wound up removing all of the Bachmann circuit boards anyway because you must remove all electrical contact points with the wheels when converting to battery power and the AirWire900.
If you didn’t receive an instruction booklet with the Consolidation, the following two items may provide some helpful informatiion:
SOUND INSTALLATION
Your Spectrum locomotive is pre-wired to make installation of after market sound systems easier. To access the sound PC Board under the tender shell, you need to:
Loosen the two Phillips head screws located near the front corners on the underside of the tender.
Tilt the tender shell towards the back and pull forward to release the assembly tabs on the rear.
DCC INSTALLATION
Remove smokebox front by snapping out with your fingers. Be sure to pull carefully to avoid damage to the wires attached to the rear of the smoke box and pc board.
Next, gently pull the wires (with service loop) until taut to give yourself working room.
Remove the two small P
