I have a Mantua 4-6-0 that’s in need of a motor. Can anyone recommend a suitable replacement (and where to buy it) that won’t break the bank? It doesn’t have to be new either, if it’s in good condition. I know Northwest Shortline makes an upgrade kit, but it seems kind of pricey to me.
EDIT: I should also state that this locomotive is just your standard DC.
As a possible alternative to replacement, you can put these new magnets in those old Mantua motors. I got these at Hobby Lobby and slipped them in here. They come 12 in a pack, this motor uses 8. You have to remove the long rivet holding in the original one. The force of the magnets will hold it together just fine, believe me. And it runs smoother, quieter and more powerfully than it ever did even when it was new.
That is unless your motor is way worn out or smoked the windings. Or you’re going DCC. Dan
After I checked this thirty-year old, but like-new, open frame motor I wired it to a decoder and it runs just fine. There’s actually two of these in my PRR DD1 and I wired one decoder to each motor.
The above photo is my temporary, trial-run wiring before making everything permanent. It is a simple job to isolate the brushes from the frame for DCC wiring.
Thank you everybody. You’ve given me some food for thought. I’m also going to check my local hobby shop when it opens on Tuesday, and there is also a swap meet on the 8th that I’ll have to look into. I’ll give you an update when I find/decide on something.
In their last few years of operation, Mantua used Sagami (IIRC) can motors in their engines. They offered the motor as a retrofit kit too. I added the motor to a couple of engines that way. Doing a search online or an Ebay search under something like “Mantua can motor” might yield something. As I recall the original retail price was like $19.95.
Hi everyone. I just wanted to let you know that I found a replacement motor locally that seems to be working good so far. I just need to make a few adjustments. Since this was my first remotoring project, I decided to go with something similar in size and shape to make the process a little easier, so I found a Pittman motor that fit the bill quite well. I’m not sure what the model is as it was second hand, but it’s a good fit that required minimal work to adapt it to the locomotive. I would like to thank everyone for their helpful tips and suggestions, and I will definitely keep them all in mind if I ever get another one of these locomotives in need of a motor.
