Need a type of plug to attach to benchwork
I want to wire a couple of female plugs oo the facia so I can plug in a couple of male plugs attached to a removable programing track.
I think I would go with barrel connectors.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313&_nkw=PCB+Mount+5.5mm+x+2.1mm+Barrel+Power+Connector&_sacat=0
https://www.ebay.com/itm/4x-5-5mm-x-2-1mm-Male-DIY-Wire-Mount-DC-Power-Socket-Connector-Barrel-Jack-New/274606678333?hash=item3fefd5613d:g:4TQAAOSwZaRf0IIz
About the most practical.
Mel
My Model Railroad
Bakersfield, California
Item number 5 on first link, would that work, already pre wired, on the one end I can attach to track as I have screw ons (old test track for train shows and the other I can use a posi-connect, so no soldering.
Yes that will work. I use those for several goodies on my workbench and layout.
And I bought the same set. I thought you wanted a chassis mount.
Mel
My Model Railroad
Purchased something like this at Radio Shack years ago but the equiv is available from other manufacturers. I like this solution as it allows connection by wire or by banana plug.
Dwayne A.
I do but I fiqure I can drill a hole in the fascia and mount the female plug.
That is a great idea too but would require a much larger hole.
I’m with Dwayne here.
I use bananna plugs that are spaced the same as the standard used on the RR AMPmeter.
Then I can splice the RRampmeter between the load and supply for a good reading both volts and amps.
I used these (or similar)
https://www.amazon.com/CESS-2-Way-Speaker-Banana-Connectors/dp/B01E7XUKG4/ref=sr_1_16?dchild=1&keywords=dual+banana+plugs&qid=1612114396&sr=8-16
You can get many styles, dual, right angle, stackable, etc. Also many types of sockets and binding posts.
I like them on the test track as I can plug in various meters and devices.
I have a rotary switch that allows me to select the LokProgrammer, Sprogg2 or MRC metered DC supply then the plug, then the test track.
I can also plug in a length of track in the paint booth so I can have the drivers slowly turning for paint or weathering. There’s a mounted Kadee coupler at one end.
Regards, Ed
Does it need to be removeable?
I wired a conveniently located stub end siding at the front of my layout with a DPDT toggle after isolating the siding. I can just run an engine on, flip the switch and Presto! It’s a programming track!
No it dose not need to be perminant but I do like to work at my desk/computer station/workbench. It is a big desk.
Ordered the parts and on the shipping ads they offered a femail plug that is mounted like I need if plan A dose not work.
I used these for two lift outs and have been happy with them. https://www.amazon.com/dp/B079RBL339/ref=cm_sw_em_r_mt_dp_7ATSBYHEEQFRKBTX0VC5?_encoding=UTF8&psc=1
Installed but not tested, no reason why in should not work. Carved a bit of the plastic on the female and shoved in in hole I drilled, thought I might have to glue it but it is wedged in super tight.
