After reading a bunch on this forum and links from this forum I’m heavily leaning towards building the Pinetop R&S GRR layout in DCC. Here is a picture of a sketch of my layout.
http://i178.photobucket.com/albums/w273/RANichols_2007/SRGRR084.jpg
What I’d like to do is start a train from the yard (block A) and go up the helix (block B). Next I’d like to follow the first train out of the yard, up the helix, and park it on the siding at the saw mill. The first train would continue on through the reversing loop at the mine (block C) and head on back down the helix. The second train would then proceed through the mine loop as soon as the first train has cleared the siding. Now I’ve got two trains running in opposite directions on the same track block with the second one going through the reversing loop and back to the same direction on the helix block before the first train clears the helix.
The second thing I’d like to do is have the first train come down the helix and go into the lower dogbone in a clockwise direction and go into the siding. I’d like to have the second train come down the helix and go into the dogbone in a counterclockwise direction to pass the first train and continue back to the helix. The first train would start back up after the second train passes and go on up the helix.
Is this possible with DCC?
Rex in Pinetop
