After putting it off for a couple of years, I have finally got around to creating decals for my fictional road, the New York, Binghamton, & Western RR as well as the equally fictitious branch line, the Munsee Valley RR. Through considerable trial and error for sizing and color matching, I’ve created two sheet of decals which to my eye look pretty good. After the ink dried I sealed each sheet with two thin layers of dull coat.
For my first effort I decided to start with something simple, the lettering on a small steamer for the Munsee Valley. I used a hobby knife to cut the M.V.R.R lettering from the decal sheet and soaked it in water. I then prepared the surface of the tender with Micro Sol. I slid the decal onto the prepared surface and careful moved it into place. I then applied more Micro Sol to the decal. I found no matter how gently I applied the Micro Sol, the decal kept sliding around so once I got it back into place, I allowed the solution to dry. I then came back and applied some Micro Set to the decal. I did the same for the loco number on the side of the cab. I then set it aside for several hours.
When I came back, the decals had dried and were adhering to the surface but the decal film was quite visible. In addition, since these were printed on white decal paper, there was a thin white line showing around the edges of the film. I tried applying more Micro Set but then the ink began to smear, ruining this first set. I anticipated some problems so a printed extras but I want to learn to do this right before I try again.
I see the decal work of other models in WPF and their decals have the painted on look with the decal film not obvious at all as they were with my first effort. What is the secret to obtaining that look and getting the decal film to disappear and also getting rid of that thin white outline around the edge of the decal? Or to put it another way, what am I doing wrong?
You are experiencing what we call “silvering” The cure for that is to apply the decals to a gloss surface. Cody uses several coats of gloss. I use Model Master.
I cut decals on a piece of glass with a fresh xacto blade as close as possible to the lettering.
My experience is with the now defunct Rail Graphics decals and DIY decals on clear decal ink jet paper. My initial experiences with DIY decals is poor. Black lettering is not dense enough against an orange background and is barely visible. That was never a problem with commercial decals.
I am not sure why you sprayed the decals with Dullcote, but that could be part of the problem.
For best results, the paint should be glossy, and the decal should be glossy. Then you coat the whole thing with Testors #1260 Dulcote when you are done.
Apply Microset when you slie the decal into position, then use Microsol to snuggle it down.
The absolute BEST decal setting solution is “Strong Formula” by Daco. You will need to mail order it from Europe, but when a decal will not set with Microsol or Solvaset, Daco Strong does the job.
When Microsol is working, never try to move the decal. You will just make it worse.
First I’m not an expert on decaling. I have been making my own decals for about 8 or 9 years.
Are you using an Inkjet or Laser printer? Both will print nice decals. I tried Dullcote to seal the decals but it didn’t do as well As I would like. I’ve been using Testors Decal Bonder #9200, it works much better than Dullcote. Also Dullcote won’t shrink around rivets and Decal Bonder will.
I also learned it takes four coats of sealer to properly seal the ink and give some strength to the decal so that it can be moved easily on a detailed surface.
I haven’t had very much luck using white decal paper; I always go with clear on blue decal paper.
I bought an Alps MD-1000 printer as a dedicated decal printer about 6 years ago and it works better than great. It applies the ink thermally to the decal paper much like a laser printer. My main reason for getting the Alps is that it will print white but it does so much better with all the colors that I haven’t used either my Inkjet or Laser printer for making decals in many years.
If you print your decals on a ink jet printer, they need to be sealed or the ink will run when they go in the water. I tried a number of clear coats, and the solvent in most of them also made the ink run. Krylon Acrylic Gloss Clear works very well to protect ink jet decals; there also is a UV resistant verson available a craft stores.
As mentioned above, the surface the decals are going on has to be gloss, or the decal will not adhere well. As to the decal moving around, that means there is too much liquid on the surface. A little liquid helps move the decal in place, then it should be wicked away with a paper towel. Just touch the edge of the towel gently to the liquid; avoid touching the decal as much as possible,
I suspect that the application of Dullcote not only made the decal more apparent (because it was thicker), but also that the Dullcote prevented the setting solutions from working on the outer surface of the decals.
While I use a fair amount of custom-made lettering (dry transfers and decals) I don’t make my own.
If I’m using decals to letter something, the first job, after it’s been painted, is to apply a gloss finish. I prefer Testors Glosscote, applied with an airbrush, but any suitable clear gloss should work. When that finish has fully dried (or cured, if acrylic), the decals are cut out. I do this work on a sheet of glass, usually using a utility knife with a new blade.
I use my X-Acto to first cut the needed images from the decal sheet, leaving as much unprinted area around them as possible. After the block of lettering is on the glass, I align the blade of the utility knife with an edge of the image - if it’s a word, for example, EASTERN the blade will be aligned with either the top or bottom of the entire word, or with the upright portion of the E or the N. All excess material is cut, in-turn, from the word, by simply pressing down with the pre-aligned blade, chopping off the unneeded blank paper, rather than slicing it off.
If you look closely at a decal word that has had the excess paper sliced from around the word, you’ll see that the edges along the cut are raised, both on the scrap portion and on the useable word portion, too, whereas the same decal with the excess paper “chopped-off”, will have its edges pressed downward along the cut. Already, even before it’s wetted, it’s better-suited to settling onto the surface on which it will be applied.
Does the type of paper matter? If not, can someone please walk those interested in in the process of making decals? This can help resolve any potential areas of confusion.
I’ve been away a few days and am just now getting back to this thread. It looks like a lot of good tips and things for me to try.
My printer is an inexpensive HP inkjet. I had my doubts it would even pass through the thick decal paper. I found I had to take the curl out of the paper by laying a heavy book plus some additional weight on the sheets for several hours. That got the paper to lie almost flat and to my pleasant surprise, it not only passed the paper but printed the decals with some fairly sharp lettering. I tried once before a number of years ago to make my own decals and they didn’t come out nearly as sharp.
I realize my mistake using the dull coat shortly after I posted this. I had prepared last year to do the decals but didn’t get around to it and had bought a can of their decal bonder specifically for that purpose but had forgotten it. Their dull coat and decal bonder cans look the same and I had them side by side on the shelf. It looked like I had two cans of dull coat so I grabbed that without thinking.
If I understand what I’m being told, I should spray a gloss coat on the surface to be decaled before applying the decal. If this produces a less visible decal film, should I then put a coat of dull coat over both the decal and the surface after the decal has had time to set? My first effort has been on a black steam loco tender and I would like that not to be real shiny when I am done.
John, the purpose of either painting the model with glossy paint or adding a coat of clear gloss over matte paint is twofold:
First, a matte finish is, under magnification, rough, and that roughness contributes to “silvering”, which is air, trapped by the decal film, in the low spots of the rough surface. The application of clear gloss gives a smoother surface with less chance of trapped air. Secondly, it also allows easier movement of the just-applied decal, so you can slide it right to where you want it.
Once the decal work is done, you’ll see that the decals are still very noticeable as decals, especially when viewed obliquely. If you apply a clear flat finish over them, the decals will often (not always) still appear very noticeable as such, since the surface of the bare decal was of a different gloss than that of the glossy surface to which it was applied. That’s why I found that a second application of gloss, over the applied decals was preferable: it makes the entire finish of the car uniform.
As you note, in most cases all but a brand new real car, just painted, would not be glossy, so another clear coat is needed. Depending on the age of the car or locomotive you’re modelling, you might want to use a semi-gloss (for a not-too-long-in-service car) or a flat finish (for a car that has been in use for a while).
Whichever you choose, that finish will be going over an already uniform finish, which will ensure that the final results remain uniform.
Indeed the type of paper matters. It has to match the type of printer that you will be using. Use paper made for laser printers in a laser printer. Use paper for ink jet in an ink jet printer.
It is best to use a laser printer because the ink fuses into the paper and becomes part of it while an ink jet printer just sprays the ink onto the surface. If you use an ink jet printer you will have to seal the paper with a clear coat of hairspray or other sealer or the ink will rinse off when it gets wet.
Also the paper comes in either clear or white. Both types are available for both type printers. Since the vast majority of printers for home or office use do not include white ink then if you want to have any white in your decal then you have to use the white paper. When the printer gets to that part of the image it simply leaves it blank. White paper is best for signs, graffiti or other picture type images.
Clear paper is better for text (letters or numbers). You can’t print white letters unless you have white ink. And you have the glare problem of the paper being shiny as mentioned above.
I hope this helps.
Once the model has been painted, you should spray the entire model with gloss finish and let dry. Then apply the decals, and use Solvaset or similar products to get the decal to snuggle down. You may need to use a sharp X-acto or single-edge razor blade to make small cuts in the decal to fix any ‘silvering’ as mentioned earlier. It’s not a quick thing, I often take a couple of days doing each side of a freight car with several coats of Solvaset, until I’m satisfied it’s as good as it can be.
Then, spray the entire model with flat finish. That will seal in the decals. If you don’t, the decal will eventually turn yellow and look very bad. Once the flat finish is in place, you can weather the model. If you weather it before the flat finish, the weathering will get under the decal and look bad. I like to use powdered charcoal for the first main weathering, as it can be sealed in with another coat of flat finish. Then you can weather with chalks etc. over that.
I used the eBay save search for a Alps MD-1000 and got mine for $140 last year. It took about a year and a half of bidding before I got it. It is my second Alps, the first one crapped out after about 5 years.
Be patience and you will find one. Make sure they ship it without the ink cartridges installed in the printer, they will come out of their holder and ding something. I had that happen twice on my first Alps purchase. The Alps printers have been out of production since 2004 and there are on repair parts available.
To me they are worth every penny and the wait, the decals come out perfect in any color including metallic.
Thanks for your kind words, Mel, but that lettering on your fire truck is outstanding!
Has anybody developed a newer version of the Alps printer? It seems to me that it’s still a very useful tool, albeit in perhaps a fairly narrow market.
While the white is probably the most useful colour for railroad stuff, especially freight cars, that gold leaf which you used for the firetruck is outstanding - as good or better than any commercially-made gold decals that I’ve used.
I’ve had three sets of custom dry transfers made in white (50 sheets each, and material on each sheet for at least two cars) and one set of white custom decals, also good for at least two cars/sheet. Before that, and in some cases, still nowadays, an untold amount of alphabet/numeral sets, both as decals and dry transfers, supplied mainly by Champ, C-D-S, and Letraset. While mostly white or black, there was a lot of yellow, gold, and Dulux gold, too.
I also learned the hard way (GRAND VALLEY / ELORA GORGE & EASTERN) that most alphabet sets contain a limited number of "G"s, "V"s, and "Y"s, and not much at all in the way of ampersands.
By the time I created the GRAND RIVER & NORTHERN LAKE ERIE, I had the good sense to use only the road’s reporting marks, GR&NLE, on the line’s only caboose and the used-by-the-locals-version ERIE NORTHSHORE on locomotives. I also wisely decided that the road was owned by the EG&E, and used their freight cars, as they have none of their own. Too soon ve get old, too late ve get schmart!
The past few days I have had the chance to put these tips to the test and the results have definitely been better than my first attempts. The decal film is still somewhat visible but not nearly as obvious as it had been. I’m using MicroSol and MicroSet and I’m wondering if additional applications of MicroSol will make the film even less visible. I plan to spray the decals with flat finish as the last step but I think I’m going to do a couple more applications of MicroSol first.
