Need dogbone connector for a Mantua loco
I own 5 Mantua 2-6-6-2 locos and need to find the dogbone connectors for the drive shaft. I had no luck on the internet and called NWSL and they don’t carry them. I’m about ready to five up.
I have an HO Mantua 2-6-6-2 and it doesn’t have dogbone drive lines. What model type of mallets do you have.
Mel
My Model Railroad
Bakersfield, California
make them out of styrene tubing, easy to do …
never heard of a “dog bone connector”
doesn’t this diagram from hoseeker show just a tube?
Sounds like it was upgraded at some point, could go back to tubing or I have seen them many times on e-bay but I think they are called something else.
Called a u joint connector, 4 on ebay right now from NWSL.
It’s a Mantua srticulated 2-6-6-2 w/tender, 345 series. The rear axle has a tube connected to the motor but the front is a dogbone shaped connector.
I went to eBay just now found nothing described as a u joint connector from NWSL.
I’ll look for tubing if I can find the right size.
Years ago I used 1.5mm/2mm RC fuel line for coupling 2mm shafts together. Worked pretty good too.
Mel
My Model Railroad
Just type in 494-6 and one will pop up. NWSL #
i had to use ebay.com rather than the one i normally use [ebay,ca] to get it to show up … it seems the seller only ships to the us, if it matters …??
Yeah, they probably won’t ship to you in Canada. Sounds like there are no sellers on eBay in Canada at the moment for that particular item. Might check directly with NWSL. Or perhaps one of the Canadian online sellers deals with NWSL and can order it for you.
345 series articulated 2-6-6-2
The tube has to fit over the spinning shaft which is about 4.5mm on one side and 6.35 on the other.
That’s the exact one I bought from NWSL hoping it would fit. They were too small
OK, what happened to the original?
The dogbone connector somehow fell out of the loco. I searched high and low to no avail.
Your luck is like mine, dropped a bran new engine on the floor, floor was carpeted and I wasn’t up high but had metal object on floor and of course that would be where it hit. Post a pic of what you want and dementions, got a box of that kind of stuff, if not me someone else might.
Good idea! Posting a pic here would be the first time for me. Hopefully, it’ll work.
If you have a real problem you might find someone here to repost your pic. Someone did one for me once. We will see if the new forum makes it easier to post pics.
