I’m seriously considering a couple ER Models Sharknose engines. The thing is, I’ve never personally witnessed how well these run and am a little apprehensive. Can someone give me their first-hand experience ? I’m mostly interested in how well they run - are they comparable to Atlas - Athearn - ?
They run very well indeed - performance is up to Atlas standards, you get a well balanced can motor and silent truck gearing, it also has a DCC socket. Body detailing is rather sparse and you’ll probably want to alter the coupler mountings to use Kadee #5s and get closer coupling (they recommend the #34 which will fit but doesn’t give particularly close coupling or look particularly good - I’ve managed to fit a #5 on the rear of mine using a couple of pieces of styrene strip to get the right height when mounted to the frame, you’ll need to take a file to the shell too to make it fit back together). Hope this is of use!
