If it is only one or two that you need and you can’t find them, you could scratchbuild it using Evergreen plastic strips. I have done that on more than one occasion.
Other makes to check out are SS Ltd., Alexander, Durango Press, Micro Engineering, and Pikestuff.
Unfortunately the Walthers catalog does not always picture every part.
Looking at the Pikestuff portion of the Walthers catalog, what about their Door with 3 panel Window, 541-1104? It is not perfect match but using styrene to create the 9 window top would be a lot easier with, essentially, half the work already done for you.
You only need two of these doors, so it shouldn’t be too difficult to kitbash them. You need to find a window that you can butcher for the 9 pane part - I believe that Grandt Line has several large industrial-type windows that might provide suitable fodder - you’ll need to find one that you can cut the 9 pane section from its centre, along with a perimeter: in other words, a window at least 5 panes wide and 5 panes high. The size of the resultant 9 pane window will determine the size that you’ll need to make the door to accommodate it. Cut a door “blank” from .015" or .020" sheet styrene, then cut out the area where the window will go. Cut a second door “blank from .005” or .010" sheet styrene, then cut the window opening slightly smaller than the opening which you cut in the first “blank”. Also, cut out the panel areas in the lower part of this thinner blank, so that the other one will show through when you laminate the thin one to the outside face of the thicker one. The window opening in the thin “face blank” should prevent the cut-down 9 pane window, when inserted from the inside of the door, from falling through the opening, yet still leave a slight amount of the window casting’s perimeter frame showing around the outer edges of the window. Add a suitable door knob and you’re done.
I’m looking at an older Grandt Line Catalogue, and their #5203 Rio Grande Southern-style windows look like they might work even better than the industrial windows- they’re a double window, each half a 9-over-2 style. You could cut away the main frame from the top, sides, and middle, and lop-off the double panes on the bottom. I’m guessing that the size should be pretty close to what you require.
If that one isn’t suitable, check out #5010 Roundhouse Windows - they’re 60"x120" high, making the panes just under one foot square.
If that one isn’t suitable, check out #5010 Roundhouse Windows - they’re 60"x120" high, making the panes just under one foot square.<
I know what you mean. [swg] I enjoy constructing those little things that aren’t commercially available, but sometimes it’s nice to be able to save that time and effort for something else.
Cut out the vertical strip in the window, and replace it with clear styrene scribed with the thinner-profile ones on the proto door you want to model. Paint the scribed lines the color of the door, glue the clear styrene into the door, and you’re done.
Walthers has a cornerstone series building called the “first street warehouse” that has windows and doors similar to those but the model has been retired. I have a bunch of them that i probably won’t use. The kit came with two different window and door styles but they were arched at the top but with a bit of styrene, can be corrected. If you happen to show up for the layout tour and can use them, I’ll turn you on to them…chuck
