Need help Identifing a Lionel model kit.
The model kit in question are the ones I used in my turtable project.
(see Zak’s Turntable)
I threw the box out so…
I would like to find the number to the kit in order to better inform you forum members.
From what I remember it was a walkway or walk over bridge of sorts.
It was molded in color plastic and was to be supported at either end by two piers.
I purchased two kits about a year and a half ago.
I would appreciate any info you may have.
Thank you
One person who may help is Jeff cane he can be emailed by going to www.TTender.com
It’s the ROW bridge and was only supported in the middle (at least each kit only has one set of support pilings.
6-12969, from 1997
I will email Jeff.
chuckn,
I don’t think it is that bridge, although it could be.
I found one set of instructions #71-2968-250. Entitled ‘Railroad Bridge’
It shows only one pier support.
But, going through my parts bin I found the embankments pictured below
Also shown are the pier supports in the forground.
Am I dealing with two different kits here?
I was off by one digit. The supports in the forground and the grey walkway are from the kit you identified. It has a single center support. The brick abbutments and wing wall don’t look like anything I’ve encountered before. Most of the abbutments I’ve seen from Lionel/K-Line/MTH are grey.
