need help on fixing a train
How do I get it unstuck from the neutral position , Its A Railking F-3 AA electric train. thanks
Would help if you gave more information, like does it have Proto Sound one or two(PS-1 or PS-2)? Do you have the parts number for the engine? This will help as MTH made a couple of versions of their engines, some engines have switches underneath for direction control but most new engines have circuit board direction control inside the engine itself.
You may have to take it to a dealer and have them reset it, or your battery may be dead… Lionel transformers will not play nice with MTH.
Roger
It is a protosound dcru set, and it has only one switch on bottom for forward and reverse. Thank’s Dick
thanks for your help it was the battery
been running my Rail King PRR Mountian for 5 years with my V
