the words 12 VOLT WALL PLUG just scared me! I hope that was a typo or you misspoke, there is no way you can get less that 120 volts from a wall socket. good luck with the project and keep us up t speed on the results, Pete
Thanks Pete. Ic ould have mis-spoke. I saw a guy oline using a one of these to test it:
And thats what I meant for the 12 volt item to test it.
I havent had a chance to try it yet! Sorry! Will try it this week and report back. REALLY appreciate all the help.
Refers, methinks, to a wall wart. Sort of thing that we used to use to power an old answering machine. Or possibly charge certain things.
They have very poor current ratings, so probably take more than that to drive these units.
Sorry for delay. So busy, so many projects. I tested it and it did not work. I had it hooked up as per Semepers desciption and in the pictures. 12v maybe not enough juice? I did it with the black and blue wires attached and without. The black and blue wire go nowhere so wasnt sure there were important. They go from thier respective post down and out the bottom and are connected to nothing.
How’d I miss this posting? Sorry to not get back to you much sooner.
From the looks of the cables you have connected, I’d say you are possibly using a battery “trickle charger” ??? Those are usually good for 4 to 8 Amps, so I’d assume you have enough power to operate the bell.
A possible cause (other than a power supply that is not capable of providing the power) would be that there is an open circuit somewhere. Some quick checks can be attempted with just the power supply you have. Just be careful to not short the power wires to each other… that includes touching the big aligator clips to each other… AND… touching them both to something that has very low resistance (no “load” to limit the current flow); such as having one connected to one of the binding posts and then touching the other one to the other end of a wire directly off of that binding post. If you are using a car battery as the power source, it is capable of dumping several hundred amps and the sudden rush of current can weld the aligator clamps to each other or what they are touching… amidst lots of sparks and flying molten metal. If you are using a trickle charger, you could still get some major sparking so be careful where you go poking around.
Sorry to be so safety minded, but I worry about offering advice to others without at least some ‘scare tactics’ to TRY to keep people safe.
Ideally now you would have an Ohmmeter, Voltmeter, or some other circuit tester to test that there is not a lose connection or a burnt out component. It is possible that the unit is broken and that is why it was sold to you.
Primary components to check would be the switch that breaks the current flow when the coil pulls the armature down to ring the bell and the coil itself. Bells usually work by energizing a coil to make a strong magnetic field which attracts a metal object (the armature) that
Wow. I cant thank you enough for the info and careful detail. Im just now learnign about volt meters and will try to figure out testing the compoents with the Voltmeter.
At first I used a small trickle charger for my motorcycle (Battery Tender). I switched to a small battery charger that you see there.
Dont mind the warnings at all. I dont know much about electricty let alone these more complex low voltage items. Trying to restore a 1967 Rock Ola wallbox and learnign a little more. Any info helps me learn.
AQll components move freely and easily - in very good shape. Will go check the switch and learn how to use this Voltmeter on the various compoents. Will report back!
Now what can you tell me about the 4 way railway light? [:D]
I just remembered another weak link in the circuit… the variable resistor has a sliding contact that could be loose or corroded such as to interrupt the current flow.
It is the large tubular, brown ceramic component on the extreme left center with the wire from the left most binding post connected to the bottom of it. That metal band/ring around it also with a black wire that goes up toward the top of the housing to the mechanical switch. It can slide up and down and must make good contact with the bare metal wires on the right side of the tube shape.
Make sure that metal band/ring is tight around the body of the component.
Contact look good on the L shaped connection. I started doubting my speed charger. I* turned it on and put volt meter on its red and black clips and got nothing. MAybe my charger is bad. Charger is turning on when plugged in but voltmeter shows nothing coming out on the red/black clips end. Going to repalce today and report back.
I’m starting to wonder if basic speed chargers aren’t enough to pover it. I ought a Stanley 8amp speed charger and it also didn’t do anything. The metal band on that tubular ceramic part is on tight with good connection.
Using a charger is not necessarily the right thing, smart chargers won’t turn on until they detect a battery… clearly the bell is not a battery. Don’t you have an ordinary source of 12 volts at about an amp? Greg
Yes, I suppose I have one laying around for soemthing. Just cut off the adapter plug end to expose the two wires? Does polarity matter in this case?
Polarity should not matter, unless the capacitor is an electrolytic. I can’t tell from the schmatic whether it is or not.
according to the schematic, the left post is positive, and the middle post negative, do NOT connect anything to the right hand post.
You will notice these are the 2 posts that had the “wires to nowhere” attached and how the previous owner powered the unit.
Also, get something with at least 1 amp… if you have a little wall wart, the output current will be specified on it.
Greg
Yes, it is marked for polarity, but as far as the majority of the components are concerned, it really should not matter. EXCEPT for that capacitor because it COULD be polarity sensitive, so I agree… follow the schematic’s markings.
The paper in the photos also states “600 milliAmps” for current, so a wall-wart type supply might work.
the only thing I could think of for polarity was that the bell “motor” might be more efficient in one polarity, depending on the steel core used… but I agree should not make a difference.
Again, the first thing I would do is apply power directly to the coil and make sure it pulls the armature down… if that works then test coil and contact, then “further out”.
Step one seems to be getting a reliable 12v supply… ha ha.
Greg
Thanks Greg. I did find a basic wall wart 12v power adapter in a drawer (1.5 amps). Will cut the plug ind off, slit the wires, and put aligator clips on the wires and use that on the posts. Hoping my battery chargers and trickle chargers just werent powering because they didnt detect a battery. If this fails I will begin figuring out how to isolate coil using a voltmeter (not my specialty ;^)
Thanks EVERYONE. Success. At first it wasnt ringing well but I had it on its side. It has to be vertical to work correclty. Here it is in working order ;^)
Thank you all for your knowledge, passion (and pateince!)!
Now can you help me with the 4 way lights? Ha ha. Will start new post for that.
I think the crossing lights are 12v, get a heavy duty automotive flasher that has 2 outputs, have you ever seen in a car that the dash light blinks in opposition to the actual turn signals? Getting one of those flasher modules should be all you need. Greg
Thanks Greg. Someone scared me once saying one side of the terminals “had top stay neutral” or somethign like that so I didnt want mess it up. On that image below Im assuming the connections are the same two posts indicated by exisitng blue connection wires?
