Need help with functions on new NCE decoder
I just installed a NCE drop in decoder #05240159 for my Atlas N scale H15-44. The directional lighting functions are working, however, I cannot get the locomotive to move or to get the marker lights to operate. The decoder responds to address programming, but still will not move. I have done a factory reset on the decoder, returning it to the original settings, but still no loco movement. This is my first NCE decoder, and I was wondering what the problem may be… any advice here would be appreciated. Thank you.
I’m not an n-scale guy, but his thread seems similar, even though it’s a digitrax decoder
http://cs.trains.com/mrr/f/744/t/271397.aspx
Once you do a factory reset, the default address is the short address of 3. Try running the loco with its short address. Does that work?
How are you programming the decoder and what DCC system are you using? Are you using the Programming Track or Programming on the Main?
I am operating on a Digitrax empire builder system. The loco is on an isolated programming track. I have added a small amount of solder to the contact points to assure a tight fit into the frame, but still experiencing the same problem… I have directional lighting, but no movement in the loco…
Are there any programming CV’s to get this thing moving…?
I have an NCE command station, so I am not that familiar with the Digitrax Empire Builder. But, as I read the manual, you can set up an isolated programming track which you have done.
Have you tried to run the loco on the short address?
Does the isolated programming track permit you to read back the long address?
It seems to me that the loco is not responding to an address, and if this is the case, you need to determine what address, short or long, is programmed into the decoder.
Following a reset to factory default, the default address is a short address of 3 in that specific decoder. Have you tried to run the loco as short address 3?
CV29 is a multi-function CV that includes a function for selecting or deselecting the long address. Can you read the value of CV29? The factory default value of CV29 is 6 which means that the decoder is set up for 28/128 speed steps, DC operation (in additon to DCC), and forward direction.
However, you would need to increase the value of CV29 by 32 to allow the use of a long address (i.e., CV29=38). A “typical” value for CV29 would be 34 (28/128 speed steps, no DC operation, forward direction, and the ability to reference a long address.
My sense is that you are not referencing the address currently resident in the decoder. It would help greatly if you could read the long address on the programming track as well as the value of CV29.
A couple of questions.
When you say that you have “directional” lighting, are you able to activate the rear light on the loco when you call for reverse direction of the loco?
Can you toggle the front headlight on and off with the throttle?
Can;t read CVs on his system. If the lights work and actually respond, the issue is that there is no power to the motor, but the decooder is receiving track power just fine. I suspect a contact issue between the motor tabs and the decoder, or a short at the same place. Most N scale locos with the fold over motor tabs require a piece of kapton tape under the motor tabs to keep them from shorting on the track pickups, but I’m not familiar with this loco.
Ok, I figured it out. Here’s what I did. Just to make sure I wasn’t going crazy, I put in the original factory DC decoder. Loco works… good, motor is not fried. I then took that out and cleaned all contact points on the DCC decoder (both to the frame and the motor pick ups). After that I applied small amounts of solder to the frame and motor pick up contact points to assure electrical contact and conduction. Then I applied kapton tape to both sides of the frame to prevent and shorts from accidental contact to the motor pick ups. I re assembled the chassis and now everything is running. So somewhere in there I solved the problem… i just figured i would cover all my bases. I reassigned the CV values for the classification lights and now they work also.
Excellent, you did good. Congrats, and thanks for the follow up.
That’s the beauty of a higher level system like my NCE PH-Pro with its dedicated Programming Track. If it doubt, place the loco on the Programming Track and read back the values of the relevant CVs.
My lesser Zephyr and the higher level Super Chief both have deadicated program tracks with readback. Once beyond the systems from the early days where the DB150 was the command station, they really should have stopped selling a DB150 based system as a complete set, it’s missing that vital function. All the current systems now have readback program tracks. The Zephyr even beats the PowerCab in that respect.
Whenever I have issues with motion or lack of motion on a locomotive, I immediately read out the values of CV19 and CV29. There are other instances as well when I want to know relevant CV values. I cannot imagine a DCC system without CV readout capabilities.
Lest a newbie gets the wrong idea, the Power Cab does have programming track capability. It requires a dedicated programming track and either a manual switch or add-on automatic switch, to protect locos on the mainline.
By that definition, so does the old Digitrax Super Empire Builder (DB150). In fact, the NCE Auto-Switch can be used with it to make the switch automatic.
