STOP!.. You don’t need a new decoder, nor do you need a new engine. You need a small phillips head screw driver, a little patience, and a little fearlessness.
The problem is simply that the contacts between the board and the frame are not seated properly.
Pull the shell off, and lay the frame down so the two screws that hold it together are facing up. Place the frame on a piece of paper towel to prevent small parts from bouncing off into the 5th dimension… Carefully remove the screws, and gently pull the top frame half away from the drive. You’ll see that there are four pads on the decoder board that nest into the frame halves, these pick up track power. There are also two tabs that come up from the motor, these carry current from the decoder board to the motor.
It is extremely important that all six of these contacts are in place securely in order for the engine to work properly.
Check the motor tabs, and make sure they are not making contact with each other or the frame. If necessary, use a small piece of insulating tape on the frame near the tab to prevent any contact there.
Next, check the decoder board pads, and make sure they fit snuggly into the slots on the frame. If they are loose, use a small pair of pliers to very carefully press the slot closed just a bit. Check the board’s fit again. Do this for both sides of the frame.
Now, press the board into place in the frame half that’s laying on the table, and adjust the motor tabs to make sure they are where they’re supposed to be. Re-seat any bits of the drive train that may have been moved about, then place the other frame half back on, and press it carefully into place. Don’t forget the little insulating washers that go where the screws fit.
Now, screw it back together, put the trucks back on, and place it on the track. If at this point it still doesn’t work, contact Atlas about getting a replacement chip.
Lee
