i have just installed a digitrax dh123at in my athearn bb and i running an MRC dcc system. i followed the instructions and nothing happen. need help and tell me what i can do.[banghead]
They are very simple to install so I doubt you screwed it up. Do the lights work? The first thing I would try is seeing if it will work on address 03. Change CV 29 to 34 and then try to run it on its 4 digit address.
You say you followed the instructions, but did you remove the motor and isolate the bottom of it from the frame during the installation? If you didn’t, the motor is short circuited.
“Nothing happened” is a pretty open category.
Can you read back the address on the programming track? If you try to set the address, what happens?
As a general rule, don’t ever put an engine on the main line without trying it on the programming track first. The programming track operates in a restricted-power mode, so that you can’t burn out your decoder if it’s wired incorrectly. If you get an error when you try to read back the engine address, you probably have the decoder wired wrong.
Unfortunately, “nothing happened” might not be quite accurate. You may have burned out the decoder by putting it on the main line improperly wired. Hopefully not, but that is one possibility.
Well, we cannot tell exactly what is going on here from the description given. Start from the top.
- Do you have other locomotives running on the DCC system or is this the very first one?
Knowing that the DCC system is running properly then we can consider the locomotive.
What instructions did you follow?
How did you get the track power from the frame into the decoder?
How did you isolate the motor from the frame?
Nothing happens? Nothing happens when? When it is on the programming track, when it is put on a meter, when it is just thrown on the track???
Are you certain the throttle is on channel 3? Does the control unit show any short circuit or error message? Does it “see” the decoder when the locomotive is on the programming track?
i follow the instructions for the decoder and for the mrc system for prog a decoder on the program track and the light come and the is a buzzing noise of the decoder. and yes i did put some tape to keep the motor and frame from tuching sorry about the spelling. i do have and youtube account if you would like to see more if you do tell me and i will make a vid of it. youtube name is guitar446
Did you ever get it running?
