Since the first time I ran the B unit the horn never worked and had problems on the track. Then today the circuit board popped and started smoking badly. When I opened it up the horn circuit board was badly fried and the foam pad had disintegrated.
I was able to locate the diagram for the 6-8184 on the Lionel website to identify the part numbers. The diagram did not show the horn parts but they were listed.
8152-50 Horn Circuit Board & 8152-35 Foam Pad. But it also listed a part number 8152-536 for speakers which I do not have in my train.
Does anyone know if there is a diagram available for the 6-8481 that shows the horn assembly/wiring? Also does anyone know if I need to add the speakers?
Any information would be greatly appreciated.
There should already be a speaker mounted in the fuel tank.
There should be four wires connected to the board. Two in are for the connection to the track - chassis and center rail. Two out go to the speaker.
The board is serviced as a unit. The components probably could be replaced if you could test them and replace as needed.
The board is available from
MY TRAIN PARTS USA
or
Brasseur Electric Trains
for around $30.00.
Ah I see it now. I was so focused on the circuit board I neglected to see the speaker mounted underneath. The information you supplied is very helpful thank you very much!
The circuit board sat ontop of a foam pad. Do you know what is used to secure the two to the train? Do I need to order a special adhesive? The circuit board was disconnected from the pad when I opened the unit. I am thinking that is why it got charred. I have never had a Lionel train burn up like this before.
Thanks again
The foam pad is nothing but double-sided adhesive foam padding. I buy a top quality replacement at an office supply store and cut it to fit. I have also used the Blu-tack / poster tack compound(4 to 6 small “balls”) as stand-offs for securing SOS, whistle, & horn boards.
I cannot thank you enough Rob! The information you supplied is everything needed.
No problem.
Welcome to the forum!
There will almost always be an answer, or 11 answers, for any question posted here.
