Need wiring diagram for DCC and DC power supplies
I need a wiring diagram for a DPDT switch set-up so I can go back and forth between a regualr DC power pack and DCC for my layout.
Does anyone have a diagram for this?
TIA
-G-
Use this diagram as a reference:
Connect your DCC to contacts 1 and 4.
Connect your DC to contacts 3 and 6.
Connect your track to contacts 2 and 5.
Also, be sure that you have a non-shorting switch. Usually a “center off” switch will be non-shorting, but check to be sure. The reason is that current feeding back from one system to the other, while you’re switching over, could be harmful.
HTH,
Steve
Thank Steve!
Much appreciated. [tup]
-G-
I used the same switch and then added two more. From the out 2 and 5 I went to the next switch center off also. I can switch from the layout to the programing track. The third switch allows me to us the programin track for either programing or test running. I hope this helps
john
