New 2 Trains
I received a new train set from bachman with ez-track and power supply. I want to use atlas track code 100. Can I still use the same power supply with the atlas track system?
I haven’t had a model train in 30 years so I’m no expert, if your in the U.S. all power is standard as long as your model is a U.S. set. If your not sure talk to a local hobby shop.
Yes, all HO track except Marklin will work - Marklin is a 3 rail system with the 3rd rail being a series of studs on the center of the ties. You can also use any other DC power supply as well.
Enjoy
Paul
You can mix track as long as you dont mix DC & DCC.
