NEW AND IMPROVED
My T/C was dismanted last fall. At the time, it was strictly DC. The new version is in design stages and I’d like to step up to DCC, Sound, etc. Doing this now, and incorporating what is needed as the construction progresses seems to make the most sense. As one may expect, there are many questions…
Are decoders “brand specific” to say, once a specific brand is selected, all after must be the same brand?
Installing decoders in older eqipment? Worth the effort?
Basic powering of the layout options?
Realistic signal operation?
Best publications,guides, etc., the address these matters?
Thanks in advance.
http://img.villagephotos.com/p/2005-5/1021009/afb.sized-1X.jpg
no , you can mix any brands of decoders . and any brand of decoder works with any brand of dcc command station
depends on the older equipment , if it runs poorly , adding a decoder is unlikely to improve it , it might even get worse if the problem is poor electrical pickup from the track . in some cases dcc gives better low speed control of the motor . also many old engines use ineffecient motors and will draw more current than newer engines so you won’t be able to run as many engines unless you add boosters
not sure what you mean , are you asking for recommendations of dcc systems ? there are lots of threads on that already
another subject that’s been discussed here , probably best for you to do some reading of old threads and then ask specific questions when you find something you can’t figure out . be prepared to spend a lot of time and money getting exactly what you want with signalling
keep reading this forum . also most , if not all , dcc manufacturers have tons of info on their websites . there are also yahoo groups that discuss every aspect of model railroading . the amount of info online on dcc is incredible , i’m sure someone will post some links , i just don’t have any handy at the moment
Here’s a good place to start:
http://www.tonystrains.com/
Look for the tutorials and info at Tony’s:
www.tonystrains.com
All DCC decoders, to be called that, must meet the standards and are therefore compatable with all base systems. However, the “base system,” which includes the main electronics parts, power boosters and throttles, are brand-specific. You can’t, for example, use a Digitrax throttle on a Lenz system, or vice versa. So, when selecting a system, make sure you are happy with the throttle control, because that will be your interface to the system. (Personally, I like the big buttons on my Lenz 100, but that’s me and my fat fingers.)
The newer sound decoders are starting to out-strip the capabilities of the older throttles. They have “sound functions” which are above the capability of some throttles. Some throttles will control only a few functions, like maybe 4, with ease. Other will go up to 12 or 13, but some of the sound decoders already exceed that.
Old engines? I pulled mine out a 40-year slumber. I tried decoders in 3 or 4 of them, but only found one that was worth keeping. Of course, these things didn’t run at all well on DC, either, so if you have quality engines that were well-maintained and running on DC, there’s no reason not to give them decoders. What I found, though, is that today’s engines are so far superior in running ability and detail that it’s hardly worth the effort unless you are sentimentally attached to your old engines. (Don’t be ashamed. I still love mine. I turned a couple of them into dummy engines so I could still run them.)
The final nail in the coffin for old engines, though, may be sound. After I bought my first sound-equipped engine, I was hooked. I immediately bought a sound decoder to upgrade the standard decoder I had installed in another engine only a few months before. And most of my old en
On Tony’s Train Exchange home page, click on the 2. DCC For Beginners. This is a good primer on DCC. You can either read it online or download it onto your computer as a .pdf file.
Thanks Gentlemen!~ Have been away for this week, and this is the 1st chance I’ve had to check replys.
Thanks, again…
