Virginian Triplex from Westside, off ebay, owner said it was 2 motor, rear motor wouldnt work. Friday it came quick checkout, wire was off tender motor frame mount, soldered, it works. This is the 3 motor version, each driver set its own motor.
I found the rear truck backwards, flipped it around oookay. More checks has trouble running, rear truck wheels and frame are hitting the tender frame shorting.
Heres the irony, all the drivers pick up one side (right side) the rear truck the left, that is the only power available, one truck, and one wheel is working, I cant get the other the flow electricity, one wheel.
I am going to grind the tender frame where its touching at the truck. Perhaps it will get it to run, kinda. My quick fixit plan, add a water tender for full power pickup, make dcc like connections to/from it. That will get it to basically run and test it.
The engine benchtests just fine it just can’t deal with the shorting on the track till I fix that. Middle driver seems to have a bind, but its not lubed up yet and may need running wearin.
My ultimate plan is to DCC/Sound it, it may take 3 decoders and 2 sound units, why 3 decoders? BackEMF control.
2 sound units, for the engine then tender, the rear driver exhausted thru a rear stack. It has high/low pressure cylinders so its not going to sound like triple exhaust unless it has a simple steam setting.
Usually this model goes waaaay over 1000 bucks on ebay, I lucked out $895, fully painted even. Nice. I think once I work out the kinks it should be a fine operator. I think I may try to add wipers on the drivers for better pickup sometime, but thats a careful and involved process.
In the meantime, enjoy the view, I won’t hide it away, if I get it running I’ll post a video.
Front/rear headlights are jewels so I gotta figger that out.
