New/different building material
I went to a local plywood distributor today to check out what they had, since everything at the box stores is pretty much garbage. They do have some godo quality stuff, for not much more than the junk at Lowes - all veneer core, few if any voids, and the ones that are present in some sheets are small, not hunge chunks missing like the stuff I looked at at Lowes. They do have various import hardwood stuff, but the 13 ply all veneer baltic birch only comes in 5x5 sheets. This actually might be fine for the support structure, where no element would exceed 5’. They have some nice smooth plain plywood as well.
The new thing they showed me, is typically sold for signs, and is designed to have really excellent screw holding in the face. It’s faced on both sides with a layer of MDF, with standard wood plies in between. They gave me a small piece as a sample, so when I get home I can post a picture of it. Being MDF on the surfae, it’s perfectly smooth - seems ideal for subroadbed. If the screw holding is what they calaim, it would be fine for the whole thing, if I use the corner brackets, since I would be only attaching things to the face and not edge nailing anything, this might be useful.
First time I’ve ever seen something like this, not something found in the box stores, for sure.
Thanks, Randy. Sounds like new methods await us with this. I surely agree about the lousy plywood available lately. The last stuff I looked at was just what you described…large filled divits and poorly made especially for the price.
MDF is good stuff if you can carry it! I lived in Scum City for many years and built a new layout after another hurricane. Plywood was not available so I chose MDF. It was easy to work with and strong and smooth. It was also heavy and made lots of dust when cutting. This MDF sandwich material may cure some issues with using it.
Thanks, again, Randy!
oldline1
MDF by itself, I think would sag too much, ANd it’s not really suitable to build structural members with - as in cutting out joists and risers. I once built a shelf laout years ago where I used some ssort of manufacturerd material that was even heavier than MDF, and a lot more solid - hard to drive nails into even. But strong - I didn;t need a whole sheet but that’s how it was sold, so I had it cut up to carry (plus I lived in an apartment) and above the layout put a shelf to hold all my boosk and magazines - a very heavy load and absolutely NO sagging. I gues it would be HDF. I haven’t seen the same thing available in years. Talk about heavy though - even the 1x6 shelf was quite heavy.
This stuff seems to combine the features of MDF and plywood - MDF smoothness, plywood stiffness. They also have fancy versions of this stuff available (which is VERY expensive) with a hardwood veneer applied on top of the MDF. Don’t need that for a layout, but it certainly is a different way to build furniture. They don;t skimp on the veneer on this, it’s not so thin that pressing a bit too hard when sanding will go right through it, which is probably why it costs so much.
I believe what Randy is describing is a form of what is known as combined core plywood. So far I have found a couple of wholesale sources, Mount Baker Plywood and Columbia Forest Products. Perhaps they are both high end for the big box stores.
Dave Nelson
Why not just go with pine 1x4’s, if you look though the piles you can ussually find all the straight ones you need, even at Lowes. Just did all my benchwork with Lowes stuff. If you ask you can find when a new load comes in.
I think that’s it - the Columbia product is exactly it, plus Columbia lists the palce I was at as a distributor in my area. The other interesting thing is that according to their map, the veneer cores used by Columbia in my part of the country are poplar.
It is often tough to find good lumber- check an independent lumberyard sometimes their stuff is better. Generally if you scrounge enough you can find some straight ones even at Lowes and HD.
I think you may have the screw holding thing backward. I would think this material is a replacement for regular MDF where you need a screw holding improvement. In my experience, I’ve found nothing worse at screw holding than MDF (except maybe masonite, which may be LDF) since it has no grain, and nothing better than plywood since the grain changes direction with every ply.
I agree with Carl.
The only way MDF works with screws is bolts.
When I built my current layout 32 years ago I used plain single side finished ½” plywood for the surface and frame. It is a 10’ x 14’ standalone mounted on heavy duty casters (850#) and it has done very good.
The quality of the plywood here in Bakersfield at the big box stores is quite good, expensive but very good quality.
I had never used USB before and because of the high cost of ¼” plywood back then I went with ¼” OSB (about half the cost) for my elevated cookie cutter roadbed including a helix. I used 1” x 3” for support about 10” spacing, 1” x 2” for the helix. I’ve read quite a few post about the negatives of OSB but unless the quality has dropped I’ve have very good luck with it.
There aren’t independent lumber dealers around here any more, just this plywood place. And driving 2+ hours each way (probably longer, considering with a fully loaded truck I would be driving even slower) to get to Sheldon’s guy is probably a bit extreme. And it would definitely stick out the back, so I definitely have to take it easy with a truck load of stick and sheet material. No hitch and no trailer, so I can;t just load up a flat trailer and get a load that way.
I don’t think I have it backwards - I said it has the smooth finish of MDF, but with the regular wood core, it has the screw holding of plywood. I’ve got my sample piece, I can run a couple of different size screws in and then try to pull them out with a pry bar and see how well it works.
Lowes and HD here both have abslute junk plywood, and the stick wood - well, the poplar at Lowes was pretty nice. But it’s like $16 for a 1x4x8’ piece. Cutting a sheet of plywood up yields me wood just as good, at about $5 a stick. Plus my time, but I have a Kreg guide for my saw to make easy repeatable rip cuts in sheet goods. I just have to get the plywood onto a couple of sawhorses and start cutting - lot easier than trying to feed a sheet onto a table saw. SO that’s reason #2 for using plywood instead of buying stick lumber.
I once used MDF to build the benchwork for a On30 switching layout and my experience was not a good one. The material is quite heavy and has a tendency to absorb moisture. Of course, screws do not hold well. Better to stay away from that stuff.
It’s not MDF. It’s plywood, with one layer being MDF, the rest is the same as any other plywood.
See quote, second to last paragraph, from the guy at Columbia, who makes this stuff.
https://www.finehomebuilding.com/1998/10/01/understanding-cabinet-plywood
What thickness? Are we still talking about 3/4" to rip into lumber?
If I may ask, where specificly are you? Maybe I can help with a source.
The lowes/HD around here have nice furniture grade birch and oak veneer plywood, I build nice stuff from it all the time? Our local lumber yards have similar products at similar prices?
I can’t believe there are no regular building supply companies around you. Many contractors will not use HD, they are buying stuff somewhere?
Sheldon
As long as there is a layer of MDF, either as the core or as an outside layer, it adds to the weight and the stuff still soaks up any humidity.
Randy, I am very interested in what you find with this possible new subroadbed material. I read your description with enthusiastic curiosity.
I checked around, and no one here seems to sell it.
However, I am making a trip to Indiana in a few weeks, and I will have a van. If this really looks like a better option for subroadbed material, I would love to know about your tests and experience.
Please keep us posted.
-Kevin
Whatever you do, don’t use 3/4 inch MDF. Won’t hold screws, heavy, dusty. Terrible.
That’s what I’ve been doing. Been fine. No need to make a PhD research project out if it. No MDF for me, no thanks. Having seen enough of that with flat pack furniture.
No, not solid MDF< I would never use that. I would use whatever my desk is made out of though - I think it’s the stuff I mentioned I used for a shelf layout years ago. I’ve had this desk almost 30 years, it was a flat pack from Staples. It was so heavy, I had to unbox it outside and carry it in in pieces. It’s moved countless times, and apart from the edges being banged up, causing chips in the veneer, it is still solid enough for me to climb on. Movers have cursed me, even with the drawers removed, it weighs a ton.
It’s 3/4. They have 1/2 as well. I may save this type of stuff to cookie cutter the roadbed, rather than make the structureal bits, but I have to try some things witht he sample piece and see how it works. The 13 plly Baltic Birch, even though it’s only 5x5 sheets, actually works out cheaper, and almost no structural member would be over 5’.
I’m in the 19609 area code.
Lowes, when I was there over the weekend, once again had the birch in 13 ply - that’s part of their problem, you never know what you are going to get. The previous time, there was no 13 ply, it was 5 or 7, with significant visible voids. This time, 13 ply (but the sign said 7… actually, there were TWO signs for 3/4" birch, one on the right stack, saying 7 play, and another sitting on a stack of 1/4" something next to it, with a $4/sheet higher price but not saying how many plies.
It’s probbaly fine for layout use, actually. I dunno about cabinet use - most of the comments are how even with very light sanding, they managed to go throught he super thin veneer, and looking at all 3, Birch, Maple, and oak, the veneer layer is so thin as to be nearly invisible from the side. BTW the oak and maple were all 7 ply. In the lumber area, the poplar was actually pretty nice. But expensive.
The guys doing my basement, they
Hi Randy,
I use MDF sparingly in my carpentry (just finishing a major kitchen and bath remodel). As others have said, MDF doesn’t hold screws, but in your case, if the MDF layer is thin enough so the screw can get a bite into the wood core, you should be okay. I would add extra blocks for support if using it for an elevated roadbed. I haven’t built my layout yet but have done a lot of woodwork over the years and I’ve become a big fan of finger-joint paint grade pine available at HD and Lowes. Very stable since there’s no grain. I plan to use it for all my benchwork.
Tim
