New electrical problem
Guys,
here is my problem. I have my switches wired to frog juicer. The locomotive goes through the switch with no issues but it stalls after it crosses the new section. This new section has insulated rail joiners to it. This new section has power it and who you run a loco on it separate from the switch it is fine.
So the problem is at the gap? What can I do to make sure the loco goes through this gap with no power loss?
i am baffled.
help!
thanks
The first thing that comes to mind is that the polarity on the new section is wrong or backwards.
Sighchris,
It sounds to me that the new section,you mention,when you say the loco stalls,is not stalling,it is shorting out,because the polarity is different…test for the same polarity,+and-,coming out of the switch and the new section as you say,the polarity should be the same +and-…
Cheers,
Frank
Are you running DC or DCC?
Need a little more info here. What make of turnouts? If the frogs are dead and fed with a juicer then why would there be an insulated joiner after it? Reverse loop or wye? Please call them turnouts and not switches. When you say switch it could mean something else.
Pete
OK I went back to your earlier posts and saw you used Fast tracks jigs. Make absolutely sure the frogs are dead before wiring to the juicer. Unless there is a reverse loop or wye then lose the insulated joiner. The rail between the frog and insulated joiner is dead and has no power. A basic understanding of the flow of electricity will help you tremendously.
Pete
Guys,
i am using the micro - engineering dcc ready turnouts for this setup. I will check the polarity and see if we are on the same page.
stay tune for more info.
chris
Chris
Check the polarity is a good thing - always. But there may be something more fundamental at play.
Keep in mind that on the ME DCC turnouts that the frog is gapped from all rails. This will mean that the two rails just beyond the frog will require feeders in order to assure power to the rails. If you are using insulated rail joiners on these rails (or some other gap) before the next track component, these rails will now be dead without the feeders. Any loco hitting these sections will stop unless the feeders have been added.
Charles
I did run feeders to these two rails. I will check the polarity next to see what if that is an issue.
thanks for insight
