So I want to make one of those black/orange RS-3s David Popp made in the September 2010 issue for my layout, but in HO. Instead of using an Atlas model though I’ll be using an Athearn model, and as you know I’ll need an RS-1 lens, which Athearn doesn’t make. Will the Atlas lens work on the Athearn model? I want to keep the detail ring intact too, so will it fit inside that?
I know this kinda doesn’t go along with this, but does anyone also have tips on decaling? I’m pretty bad at it and I want to do it right. I’ve got an old SD40-2 shell I’m going to practice on, but maybe there’s some secret I’m missing out on?
Bowser sells loco detailing parts. You might be able to find the type of RS headlight that you want from them.
As for decal application: Decals should be applied to a very glossy surface. Use Micro-sol or other decal setting liquid to get them to snuggle down after the decal is in place on the model. Before I apply the setting solution, I remove about half of the water that is on the decal from when it was transferred form the water to the model with the tip of a facial tissue. (klenex)
Once you apply the setting solution, DO NOT TOUCH THE DECAL or move the loco shell until it is dry. Then you can decal the other side. Then let it all dry for a day or so and spray the shell with clear flat.
By the way - the glue that holds the decal to the paper is not used for holding the decal to the model. It is just used to be able to release the decal from the paper it is printed on.
Um, Athearn does make both the twin sealed beam and the single bulb reflector headlight versions.
If you get the Undec. version of the Athearn RS-3, it comes with both headlight options.
BTW, pay attention to the NH numbers as not all RS-3’s got the McGinnis treatment, nor did all black-cab/orange-hood’s get the same headlights (but I think all orange-cab/black-hoods remained single bulb). FYI: Custom Finishing detail parts have many NH-specific RS-3 details available.
As for decaling:
1). To start, try to get the area to be decaled finished with a gloss coat. Decals like glossy places to lay down on. This can prevent “silvering” (where there’s air trapped under the decal in many tiny bubbles). It also goes without saying that the model should be clean and dry.
2). Wet the decal for 10 seconds, then place on a paper towel, sponge, or foam. Wait until the decal slips freely from the backing (use a toothpick to check).
3). (Optional) Apply Microscale’s Micro Set to the area to be decaled using a paintbrush.
4). With tweezers, grab the decal paper backing (move the decal slightly off an edge) and bring the decal over to the model. Use a toothpick or paintbrush to slide the decal off the paper onto the model (and into the optional Micro Set solution).
5). Position the decal, then wait fo the decal to dry slightly. One can blot some of the water away, but be careful not to disturb the decal. Let it dry a bit until the decal sticks to the model, but do not let the decal dry underneath. You want it moist as it will allow the setting solution to wick under the decal.
6). Apply Microscale’s Micro Set (presumably you’re using Microscale decals) using a paintbrush. Don’t disturb the decal, but apply an even coat of Micro Set. Do not let it puddle
Thanks for all the decaling help! I think the key too is practicing… I’ll work on it and see what I can do.
As for Bowser, I had a hard time navigating their site but I’ll keep looking… And I found out that Athearn made the B&M model with the wide lens, but I can’t find it at any online retailers, and apparently the undecorated model is discontinued. Big shame, I would’ve easily bought two or three of them.
For Cal Scale parts from Bowser, click on “HO” on Bowser’s main page. About halfway down the page under “Tradition Locos and Detail Parts”, click on Cal Scale Parts. There you will find a complete listing of all the parts from Cal Scale.
Thanks for the help with Bowser’s site. So I’m guessing that I want the single lens, yes? Also, it looks like it has the ring molded around it. Would I have to sand off the Athearn’s ring then?
Yes, you probably want the single lens. You would most likely have to remove the ring on the shell. However, I wouldn’t do any modifications on the shell before you get the parts and see what has to be done.
Now having said that, if you have a set of jewelers files, it is possible to enlarge the headlight hole, leaving the ring. Then put a lens in the hole and you now have your single lens headlight.
The brass cast headlights don’t come with lenses, so you will have to get one or make one.
