New HO garage 13x9 Layout
I wanted to give credit another member in this fourm for the great idea. I’ve been looking for a more interesting layout than my double mainline oval. Good thing i only layed track so far on old layout. Layout
Any Ideas for suggestions would be great. I plan on using modern Loco’s and mostly UP. Reason I used 5x10 and not 4x8 (though thats was what i started with) was because I wanted larger turns for SD70ace, 22in radi is the smallest turns. Will be all DCC with NCE.
This post has just been hanging without a response (but has 200 hits). I think the reason may be that nobody wants to be the bearer of bad news?
A figure 8 design in HO is a real challenge. I tried this with my first 4x8 layout many years ago and was not at all successful. It looked pretty good but operationally it was a mess. Grades were too steep and on tight curves, vertical easements were too short, turnouts on grades were problematic, tracks at different levels were too close together, and throw in some S-curves… it was all but un-usable. A few months ago there was a post by a member here with a similar design already built, with exactly the same problems. After a lot of discussion how to make it work he decided to start over.
In theory going with a 5x10 should help a bit, but since much of the extra width on the proposed design is taken up by the yard the gains are minimimal. And the extra width makes it much harder to reach into the center to work on the critical track there.
Not saying its impossible, but more than I am willing to try (been there, done that.) If you really want an over/under crossing in HO I suggest you think about an around the wall style layout instead of an island. That gives better opportunity to lay track long enough for reasonable grades. Here are some general guidelines based on my experience- both back then and now.
  • Keep grades well below 3% especially on the mainline (2% is a good max target)
  • Keep grades away from tight curves (anything less than 26" or so will make them act significantly steeper)
  • Allow for vertical easements in the design (transitions from grades to level track are needed to keep cars coupled)
  • Provide enough room between tracks at different elevations to enable building a hill, rock face, or some sort of wall between them
  • Avoid putting turnouts on steep grades
All of the above is especially rec
Yeah i was wondering why im getting so many hits but no replies. So yeah I dont like Point to Point operation. I like to just let them go and take it in or take pictures. I really liek operations and doing stuff like moving cargo from one area to an other. the Area I have to work with, (rather allowed) by Wife is garage :-). so I started with 4x8 but started to get 6 axel locos and wanted larger turns, so I went with 22 and 24 inch turns and increased my area to 10x5, you can keeo the turns on the outsides and have 26-28 turns. problems is that ovals are boring and thats why i went with with set up. I been playing around with an lumber area in the right side mountains using 15in turns ( short switchers and short 1-2 cars. I know 15inch is doable.
So yeah, If someone can lead me to a better Idea Im all for it. But Space is limited me. I can add maybe 2 more feet at end of table and have 5x12, If a dogbone design was doable in 5 feet lenght that would be cool, but i dont think it would fit right.
Content removed due to a completely fucked up and incompetent Kalmbach customer service.
Svein,
Excellant advice! Forgot about Byron’s work.
Cheers, [D]
Frank
I agree completely, Byron’s site is an excellent place to get ideas. And since you know how to use design software you should be able to come up with a really nice, interesting track plan if you are willing to move away from the island concept and put some time into it.
I am not a point-to-point guy either. I would describe myself as a modeller more than anything else, and like to be able to watch the trains run hands-off. My new design is an around-the-wall dogbone and yes it has elevation changes and a crossover, but all the grades are 2% or under, and my min radius is 24". The total plan fits in 13x14 ft space.
I am still waiting for someone to post an operating HO figure 8 layout that is truly successful- just to prove that it is possible. But I haven’t seen one yet. Closest is the Virginian since it has some of the same elements and looks like a fun build, but the design is not a true figure 8.
I thought I made this clear but maybe not, the Layout is in a garage. one side of the garage is a wifes car and other side is shelves for storage, so train table in in between that wall of storage and the car. I bearly have walking distance around the layout as it is now, but its usable and workable. I know of the pages and sites that show how 4x8 is bad idea and the usable stuff on outside could be used. I read all about that stuff. but when your really stuck to that Small of an area, you have to use what you got. Like other posters said once you start your always craving more area! I have a Club layout i can us efor my Long Train runs with 40+ cars if i want. I thinking for at home just 6-8 cars max, maybe small local freight. I will post a new layout design when I get home, just made some changes. my max elv change is 3%. everything i read says its possible. all my turns are 22 or 24 turns. My trains are pretty heavy (MTH) and i did a test with 8 cars with one GP 35 (MTH) and it pull up with a much higher than 4%. I been searchign all over the interwebs for a better 4x8 or 5x10 layout, very hard to find… Also I will mostly run boxcars, coal, wood hoppers, local frieght, not really intermodal stuff or passager cars. my locos are 2 GP60s, 1 GP 35, 2 SD70ace, 1 Alco S4.
Unless Im reading your drawing incorrectly you have less than 3 in of separation between railheads (I see 2 31/32). Thats not going to work out very well for HO scale. You need at a minimum 3in of separation. With 22" curves you would need approximately 2.1% grade over 12 linear feet of track (one direction), less since you are going steeper 3% is 8ft of track. These of course are approximate numbers obtained from John Armstrong’s book. You will probably need more than 3in of clearance for running certain modern equipment.
If you are limited to a table top, a scenic divider can break up the round and round illusion, as the train disappears and reappears. I have only a 4’x6’ in HO, but with the divider I can have a little yard on one side and could have one on the other, but for now I only have a passing siding. You can easily have one train slowly loop while you do some switching in a yard. When your incoming train gets to the yard, it can either drop off its cars and pick up a new group or the other loco can pull out with its train and the incoming loco can switch what it brought in. With the passing siding, I can have one train disappear, then another appear from the same direction the other one left. It can drop off/pick up cars then be on it’s way. The other reappears and does its thing at the yard. Simple, but has continuous running when I want and limited operation when I feel like doing it.
My divider is neither centered nor parallel to the sides of the layout, breaks up the straight lines of a small table layout. It comes within a few inches of the end of the table, but with a larger table you could move it in a little. To disguise the ends a tunnel, buildings, trees, bridge or as I did on one end, a deep rock cut, make the trains disappearance less noticable.
An around the room shelf gives you more options, especially for your larger locos, but a table can give you some fun too.
Good luck,
Richard
i should take a picture of my garage. hehe i have tall wall lockers and standing 2x8x4 shelves. no chance of moving that stuff. If I make a drawing of my area if anyone could come up with a better design I will look at it. I would be very greatfull. I dont have much train ppl here in hawaii to talk about so this is my only outet for creative ideas. Ill post a picture of what i have to work it. Im 29 yo and only been in this hobby for 1 year, so i wont be at all upset at and remarks like thats a bad design… It may very well be.
this is the latest changes to my layout ( Still want input or any ideas that i can change) I added 15in track at top of mountain for a logging area, only small locos and 1-2 short cars will be up there.layout 3
I hope you all can see thisspace
This is the space im working with. I do have some space on the Left side to make it longer , maybe 4 feet without getting to close to garage door. If anyone else has something to suggest. Im more than willing to hear you out.
Here is just a thought based on what I’m reading and how you might squeeze a little more size for your 5x9 layout, maybe you can make it a little wider and get away with it. I realize you said you barely have room to get around the 5x9 on the side of the garage available opposite the spot still used by the car.
If you build the layout on wheels - each of the four legs had large diameter wheels, it will be easy to move it back and forth. So maybe you can widen it even more. But since wider means you can’t get around on one side now, when you do need access, you can simply roill the layout back over and go around the other side to work on it, and have access to trains on that side. The rest of the time you will have access to 3 sides which should be good a lot of the time.
If you can add even 6 more inches to the layout width, it could make a huge difference on standards, curve radii, yard and operability. You might be able to get away with even more width like adding on 12-inches if you only need access one one side at a time! Heck if the sides are the biggest limitation maybe you could go crazy and make it a 6 x 12! Just install large wheels on the bottom and maybe you can have enough space to make some major improvements to the track design and geometry.
Here is what I’m doing. I built a small room using about a 1/4 of our garage. My wife parks her car next to it and I park the riding lawn mower in front of it. The layout itself measures 8’6 x 6’6. These photos were taken over a year ago. The room is now completed and I have an operational, but mostly unscenicked layout. You can see my start on the drop bridge. Since it is a bit small, I am running only 40’ stuff and shorter instead of the 50 footers shown. I do prefer being in the middle of it and having a train run around me.
Do you have more than 1 car. If so you may want to consider making the layout stowable. Im not sure how often you guys get typhoons out there but you might want to consider being able to put a hypothetical 2nd car in the garage. This would also assist in moving it later, if you were to relocate at a later date. Moving the layout is something new model railroaders often do not consider when building. Folding or removable legs would go a long way towards this. Just something else to think about.
You could probably stretch out the layout into a 12x5. I dont reccommend a 12x6 because you wont be able to reach the middle very well, and would have to be constantly moving it back and forth. Reaching more than 2.5 feet without a specialized ladder may have bad results for your scenery and rolling stock in the yard. As well as knocking things off the track when rolling… or the table rolling into the wife’s car…
You also need to consider how tall the table will be. The taller the table the less distance you will be able to reach, but in many cases the taller the table or rather the track height the better the trains will look. The height of the track from a visual perspective is an opinion, individual results may very. My girlfriend is a helicopter pilot and likes the top down view of things… I however like to have it closer to eye height.
I once thought about a N scale layout for a submarine rack on a 688…then decided that was a bad idea.
I built a layout in a garage that the nose of the car could fit under one end. It was a hollow L 16x19’ in size with minimum mainline curves of 30-inches, a sizable yard and storage/staging tracks inside the reverse loops at each end that were stacked on top of each other. Basically it was a reverse loop to single track to yard, to single track to siding and then to then reverse loop at the other end. All in a 2 car garage that one car could fit in.
I did something close to what you are trying to do with your layout. I am providing my plan so hopefully you can use it along with the ideas that the forum has provided you and create something special. I have deviated from my original plan. I started with a 4x8 table, I added a 2x10 extension to one side to accommodate a yard that I really wanted. I have only two industries instead of the many that you see on the picture. I have a grain elevator and a corn syrup plant currently. You can utilize every nook and crany. I also added a 1x4 extension on the end by the diesel shop to accoommodate a longer yard lead. My current layout still allows me to reach at least to the middle from either long side, however, I am 6’3". The layout is about 43 inches tall. I wanted a yard and I wanted to be able to do some switching at industries and wanted to run my trains around and watch too.
Here is the original track plan:
Original 4x8 trackplan
This is a picture of my current layout. It is really experimental.
Current Layout
Good luck.
http://trainluver.shutterfly.com
do you have any recent pics of the layout?
Ok. so I’ve been in the garage all night thinking.
this is what i currently have in here.now
Bit of a mess, but im a guy. :slight_smile: so I like the other guys idea of creating a room inside, Would like to see that finished. but I have these white hanging storage things connect to my rafters, so i cant do that. I need to be able to access the stuff up there from time to time.
Here is a mesurement graph.
graph 1
So i starting to think from the ideas in this post. What if I make some room. Well those 5 storage shelves are not really being used to much, I can seperate them from top and bottom and relocate them. Maybe under the layout! But my current layout is just a tad to short at 3 feet tall. If i raise my layout to something like 43in high i can fit them under. So then I was like maybe I can do this.
v2
So now im looking at possible a L shape layout. I added 3 feet to end also. SO yeah. maybe i can do this. But I need to raise table. one thing about my garage is the slight slant for water runoff. at 10 feet I had to raise the end legs 1.5 Inches. so maybe if someone has an idea for a module table idea. might be easier to make new benchwork. Let me know what you think.
