Hi, I’m a new user here and a new model railroader. I got my first model train for Christmas when I was 8 and it’s been a dream of mine since then (30 years) to get into the hobby, so I guess better later than never.
I have my benchwork build already, the layout is attached in below. I’ll be using N scale. The top and the left sides are adjacient to a wall and window so they are less accessible. The total lengh is 10 feet.
The initial inspiration of what I want to build is a slightly smaller version on this 4x12 layout below but I would like to add a town and at least one industry somewhere.
Here are some observations and goals for my layout:
I have a half inch plywood on top of the table and I’m thinking of using a 2 inch foam on top to be able to have some elevation changes.
I bought the Kato Unitrack starter pack, it’s solid and good quality. I’m a little bit concerned that it has zero flexibility and look wise it’s not that authentic, especially for industry areas.
I don’t want to prototype any specific place but I do like authentic look for the track, scenery and surroundings.
I’d love to get some tips on how you guys would plan the layout
Thanks for posting your layout. It was easy to open and the software tool looks really interesting to use.
Like you, I have my first layout operational, so what I can suggest is coming from a relative novice. To start, you might want to pick up John Armstrong’s well-known book about track planning and Jeff Wilson’s on getting into the model trains; the latter is much easier to read and the former can serve as a life-long reference guide.
For the layout, I would remove the circles on the layout and create a point-to-point set up. Of course you can still have sidings for industries. I also would have track go over the water to give more eye appeal than just a waterbody. The double-ended tracks (in the middle) can also serve industries. Having less track is more realistic than trying to squeeze too much into a small space.
Those are just my thoughts and I look forward to what my more learned colleagues can offer.
You are going to have issues with the top and left inaccesible areas because of reach. I would shoot for a maximum of 24" width to reach anywhere on the layout from where that point on the layout is accesible.
I’m strictly an HO guy these days, but did build an N layout back in the '80s.
On my layout, I sacrificed ease of reach for more layout space. While your 4 ft reach is significant, its not a major problem - if you take care to make the trackage and wiring “bulletproof” in those areas.
Take the time to assure there are no kinks - either horizontally or vertically, and that you apply feeders every 4 ft or so, and on each of the stub sidings.
Extra care taken now will make a huge difference later on. Gee, how do I know?
Thank all for the tips. I know I have an accessibility issue on the top left corner but I’ll try to work with it. I have some flexibility to move the table but not much. I’m on the fence on doing point to point of circular. I’m not sure the surface is big enough for point to point but I don’t really have much experience to judge. In the meantime I’m playing around with RailModeler Pro to build my layout but it’s not easy with the unitrack. I’m also reading the books mentioned so get more insight.
I am a few years into building my HO layout. Not my first railroad if you count the 4X8 that I built years ago, but still a relative novice compared to most here. Having gone through this recently with success so far…
I am hardly a layout design expert but I like your basic plan. Some folks really like point-to-point and some just have to have continuous operation (loops at the ends). I fall into the latter camp, but its a trade-off either way. I’ll let the operations experts drive that part of the discussion. Also I am not familiar with N-scale so can’t provide any advice on track or turnouts. But unitrack would not be my first choice for the reasons you mention.
Reach is a big consideration especially if you want nicely detailed scenery. My first phase was a 5x8 section and I built it as an “island” and concentrated on the back and sides that eventually would go against walls. Once finished I pushed it into place. This worked really well. If you make sure that your benchwork is good and stout so it can safely be moved, or better yet put it on casters, then you can do the same. For me that first section can no longer be moved but I do have an access hole in the center so I can still work on the rear if needed. The track has proven to be bulletproof so I will eventually fill the access hole with a popout scene.
You should decide on a region and timeframe for your layout before you get too far into it. If modeling a relatively flat area then its a lot easier especially for a beginner and you can just keep all the track level and add some simple terrain changes using foam as you suggest. If you put the track on top of 2" foam then you can carve into it to get some landscape below, and add more foam on top for hills and mountains.
Track elevation changes make getting good dependable trackwork a lot more challenging, at least for HO, and require different construction methods
Since you have reach issues in the upper left, I would refrain from putting turnouts or places to uncouple cars up there, that’s when derailments usually occur or where you need to reach.
OTOH, using that space for the back side of a loop really doesn’t invite many problems unless the radius is too tight.
You might want to plan on having that area buried in a tunnel and have a hole in the benchwork for access under the tunnel too.
Also, I’m not a big fan of secional track, which the Kato product essentially is. As you noted, it limits some flexibility and realism to the look.
In some cases, there is only one shape of benchwork that will maximize a given space, like an around the room donut design, so there isn’t much reason to mess around with computers or paper to design a specific, detailed plan before building the shelves.
In that case, I guess technically, the trackplan has already been decided as being a big loop, but where the specific features go can be designed on the benchwork and the builder can see the viewing angles and such in real life and adjust them to his liking.
Nice job on the Kato roadbed. I’ve used Kato track for a few years (the stuff is bulletproof) and I think it is underated by many. It may be sectional track but you can do some interesting things with it. There are a few videos on youtube on how to work with the track. One of my favorite videos is to turn straight track upside down, then saw (crosswise) from the bottom of the roadbed to just below the track ties. Cut every 1-2 inches and you can slightly bend the straight track to make easement curves or gradual S curve bending to eliminate that straight track look. It is a little bit of an effort, but I’ve had much less issues with Kato track then some of the other brands.
