New Layout
Hi guys, I don’t post much, just like I don’t talk much, but I do read a lot of your post. I am moving to a new house where I will have the entire finished basement for my new layout. I run my current layout with a conventional transformer with conventional engines. I am planning on buying a legacy expansion set for the new layout. My question is how do I run my conventional engines with the legacy? Do I need to get a TPC 300 or 400? Thank you, Marc
You will need a TPC 300 or 400 for each seperate loop or block I believe that you will be running your conventional engines on. If you want to run them by command controll
