new layout
I have recently moved house and have some room to spare in my garage. I can use an area 3.6metres by 0.8 metres. If anyone has suggestions on a layout or even a track plan, let me know.
That’s about 12 feet by 2 1/2 feet?
There are lots of plans for switching layouts and other “small” layouts at these sites:
www.carendt.com (Not working this morning, but usually up - check back soon)
http://www.naisp.net/users/mfischer/m_train2.htm
http://www.wymann.info/ShuntingPuzzles/small-layouts.html
Good luck!
Andrew
looks like a point to point unless the scale changes
Depends on the scale … in N scale you can do a turnback loop in 2-1/2 feet. In fact the space you list could house a really nice N scale layout if you are okay with that size.
As I get older, I am really glad I went with HO (which is roughly twice as big as N) since I like the extra bulk and things are easier to see for these aging eyes. And the ability to easily add sound and lights to my locos is a real plus. Those extra little goodies really enhance the train running experience like nothing else!
The Seagull West approaches Roseburg on the HO Siskiyou Line
Try a small switching layout unless you reallllly want continuous running, and that will be hard. Use a maximum of N scale if you want continuous running.
thanks for the replies guys, I will be working in N scale and will probably go with an out and return style of layout.
Andy
There is another option particularly in N gauge and that is to install a running track around the garage. It wouldn’t take more than 4" and you could box it in with a plastic front in a box. It would give you a place to keep the trains where they wouldn’t get dusty and some continuous running. I suggest a box because then you also hang tools and various necessities on the walls and not worry about interference. just make the front removable so you can get to the trains if there is a problem.
The hobby shop I buy most of my model RR supplies from used to have a nice N scale layout that was about the same size as you’re talking about. It was continuous-runnig and had lots of nice scenery, as well as a turntable and roundhouse and a moderately sized train yard. They also had some very nice mountainous scenery on one end with several bridges and tunnels.
