New Lionel SD-90 Won't Run Need Help!!
My new Lionel won’t respond,i can only get sound.Iam using a MTH transformer on lionel Fastrack.Yes it is command control, but won’t run in conventional mode?I do not have a lionel transformer. Need any help i can get.I read owners manual no help!
If you have other engines that run it’s not the transformer. If the train is new take it to any Lionel Service Station for warranty repair.
Conventional trains are a snap to fix, but these new electronic gems are not.
Is the switch on the bottom on Prog or Run?
