New MBTA rail cars
Springfield is about ten miles from where I live. At least they will be built in the USA. CSX mainline not far away. Just no siding for the place.
We shall see.
http://www.masslive.com/business-news/index.ssf/2014/03/cnr_changchun_railway_vehicles_berkshire.html#incart_river_default
It amazes me that the various transit agencies across the country each believe their situation is totally unique and that no other agencies vehicles will perform to their needs and feel it is necessary to reinvent the transit car in their own image. Talk about wasteful - wasteful of taxpayer money - wasteful of design resources - wasteful in every way you can define waste.
I’ve often thought the same, BALTACD. But you are dealing with fiefdoms and their attending politicians here. I remember when a DL&WRR station was “saved” by a small upstate NY community figured they had the only DL&W station in existence, that it was just like a LVRR station about 40 miles away, and who refused help from railfans an local railroaders in helping pay and do the work of restoring the the depot. My estimation was that they spent almost 10 times what it could have cost them in both time and money. But they knew better what their depot was. Same when it comes to these “authorities” and “agencies”. Local, only ones with this problem, don’t want nobody’s help, don’t want to be like anybody else. So you have differences in inches and feet, in colors, placement of doors, electrical attachments, etc. And suppliers drooling all over the prospective paychecks they will have for such nonsense…
I’m with you guys. The Orange Line cars are approaching 35 years old, and are in need of replacement. They are based off of PATH’s PA-3 cars, although heavily modified. So, there is some commonality, but rarely. (PATH has the same loading gauge as the NYC Subway, but refuses to co-order cars with the MTA…)
Pardon me, PATH cars are wider at the belt rail, thus have bulging sides to take advantage of better clearances, thus are a bit roomier inside. They are also designed to take sharper curves than A Division (IRT) NYCTA cars. So there are good reasons for the differences. The TA could use PATH cars if they relocated a lot of signs and signals throughout the system. Both systems order enough cars at one swell foop to make further economies of scale problematical anyway.
But, Dave, aren’t the H&M standards the same as Staten Island and specs are almost if not entirely compatible?
Truer words were never spoken. I suppose that was one reason why the “Standard Railroad” was the envy of the world eons ago.
It took a major effort to get the PCC streetcar designed in opposition to the existing mentality even at that time that each operator had distinct characteristics that precluded standardization. While the PCC car war fairly standardized, it was never intended as a “one size fits all” design. Modular construction with a variety of options took care of the variations from system to system. Also consider that the three major designs of PCC rapid transit equipment (Chicago, Cleveland and Boston) were quite distinct from each other in appearance and were also different from the various streetcars.
Staten Island cars are the same specs as NYCTA B Division, BMT and IND lines, now combined. Indeed, the B&O had the original cars designed to fit the BMT A-B "steel"car envelope, with all characteristics for capable running over the 4th Avenue Subway and the Manhattan Bridge, and the ports off the 4th Avenue subway at Bay Ridge for a future tunnel to Staten Island exist to this day. Current Staten Island equipment are standard R-44 B-Division cars, with a f ew FAA mandated modifications since freight service may be restored to Clifton. And once the Arlington and South Beach SIRT service was cut, leaving only the existing Tottenville line, surplus SIRT cars were used by the TA, specificalliy on Culver, and then on the Culver shuttle. The PATH cars have the same width at platform level as the IRT cars. SIRT = BMT and IND. In all cases there is third rail compatibility for all these cars, and with LIRR as well.
We expect R46’s to replace R-44’s when new car deliverities make them surplus on the B Division.
A major place to save money is the control and motors that run the cars. By standardizing these one could save considerably. The biggest savings are down the road when you need to replace worn out motors. If one had standard mounts one could exchange as needed. In the SMEE cars of NYCTA were an example of this. NYCTA could plug together a train of several different types from R-11 to R-36’s. Rgds IGN
PS. Pullman Standard tried to do this with the R-46’s. Building a railcar that could be narrowed widened, made shorter or longer. Unfortunately the R-46’s broke the company. Rgds IGN
This is true. I should have been more specific. The H&M K cars were about the same dimensions as the IRT cars of the same era. However, as you say, the orders are large enough that engineering costs can be spread across all the units. The real target should be the $3 million streetcars.
From what I have heard, the R44s on the SIRT are held together by metaphorical gum and duct tape, and are in imminent danger of falling apart in the next few years. I think a few have been retired for this reason.
Are all of them gone from the Subway? I think at least one is in the museum.
The SIRT cars of 1925 not only had the same dimensions of the A-Bs, they shared the center door(s) and roof arrangement. However, the end doors, and cab doors, were similar to those on IRT stock. Those sent to the Subway went there about early '50s?
Yes, early 50’s, but possibly as early as 1949. Remember that wood el cars were still providing Bay Parkway - Coney Island shuttle service with all rush hour West End trains terminating Bay Parkway “because of a shortage of steel cars.”
Full-width-cab use of front vestibules was standard on all railroad and interurban mu cars at the time, and the BMT steels were a departure, with their small corner engineer’s cabs. The IRT adopted this change about the same time, with the earlier “Gibbs cars” using the entire front platform (and most keepinig this arrangement until retirement, found only on the Broadway-7th Avenue and 7th Avenue locals.)… The B&O did not want to force "their"engineers to accept to the innovation of a small corner cab.
In the late 60’s when the SIRT cars finally wore out with repare parts hard to get, some postwar LIRR Pullman-Standard mu’s replaced by M-1’s saw service on SIRT until the R-44’s arrived. They were returned to LIRR to become non-powered trail coaches for the diesel services.
From what I have seen, you could probably say the same about fire departments. In earlier times, railroads tended to have their own specs and requirements, sometimes even eccentricities (the oddball headlights and other warning lights on SP diesels come to mind). But at least it was their own money they were playing with.
John Timm
Just curious…
I wonder how much the cost of each vehicle is increased by the requirement that the successful bidder build a new local factory and train many new employees. Are they offering any incentives other than the purchase of the railcars?
Thanks.
And the Culver steels did not get beyond Kings Highway during the rush, but there the el gate cars ran all the way to 9th Avenue for connection with the West End. After the A started running to Lefferts, C-types from Fulton St.replaced the gate cars, and these were replaced by a real abomination, IRT Low-V’s with longitudinal flanges added to the bottom sides to fit them to the wider clearance platforms. Then came the D-train and the Church-Ditmas ramp.
Those cars remind me of the London Tube R Stock. They seem to have an ‘angrier’ look to them. It is interesting that the shops went to the trouble of fairing the side extensions into the body, as opposed to simply welding a shelf to the frame at floor level.
The Orange line trains started arriving in late spring 1981
