New Member, and New Project. N&W Hi Nose C425.
This is my N&W Hi Hood C-425 Phase III Project. The unit is an ATLAS Phase I with a Stewart C-630 Hi Hood and Cab (at 15 dollars for the 630 shell, this is the most expensive hi hood I’ve purchased to date). This modification was a little more involved than I thought it would be because the Stewart hood sits a little lower than the ATLAS does. I had to build up the bottom of the cab a bit with plastic. The cab steps are from an ATLAS Canadian Cab C-424 as is the fuel tank. I still have to make the battery boxes that go under the walkway.
From one Ohioan to another … welcome ! That project looks quite impressive. Keep us updated.
Thank You, I will. I’m from up Ashtabula way.
Newark area here. When I saw the Coshocton, I thought perhaps you were in the next county over. Go Buckeyes !
No, I model the old W&LE Zanesville line.
Excellent! And no masking required to paint the unit!
Just a slight pedantic nit – I think the three-width stepped radiator housing and snow shields over the central air intakes qualify the prototype unit more as a Phase IIa carbody; the IIb’s (or “III’s”) had two widths of sheet metal for the housing and no snow shields.
Beautifull job so far [tup] Nice to see that some people still actually model and kitbash things.
Rob
Welcome to the Group! [#welcome] You’re doing a sweet job on that loco! Yes, it is nice to see someone who still kitbashes. Keep the pics coming!
Paulie
Looking good Randy,Welcome to the forum!!
Way to think outside the box!
David B
[#welcome][#welcome]! That high nose C425 looks like a RS-11! Keep up the good work!
