I have a problem with new MTH SD70, I just bought at YORK. Seems when I start to go at slow speeds it will lurch, or hesitate,then about 5 minutes later will slow down when it is running at about 50 MPH. Run a little bit more and it will come to a stop. Gave it the feel check above motors and they are very hot. I reprorgramed the engine but it still does the same thing in forward and reverse. Anyone know anything bout this? Do I have to contact MTH or is there and easy fix? I did pre lube all points. Thanks for your info.
laz57
